Can someone verify my wheel calculations?
I need tires for my 85 Corvette this summer, the ones I have are dry rotted and I'm not comfortable going around the corner with them. I have a line on a set of 2002 Camaro SS 17x9 35th Anniversary wheels and tires. I have the Z51 option in my 85 so the offset is +38mm and I'm fairly certain the Camaro offset is +50mm. The bolt pattern is the same but I'll need spacers, correct? I'll have to use 12mm spacers to get me where I need to be if I remember correctly. Any suggestions or advice?
Plug your numbers into this and see what you get: https://www.wheel-size.com/calc/?whe...cl=50mm&sr=0mm
Personally I won't use spacers, too much potential for problems IMO. |
Originally Posted by hcbph
(Post 1598992433)
They will fit but as stated you may need spacers. I have spacer's on both of my 85's, a base and a Z51. Haven't had any problems and the base has seen drag and track time. YMMV.
Originally Posted by ejscarfo
(Post 1598992298)
I actually have spacers that have their own studs and use the existing studs to hold them on. They are much thicker that what I need but they were what came on both cars. They work and don't look odd so I didn't change them. I would say to make sure you get hubcentric no matter which type you choose.
Originally Posted by Joe K
(Post 1598996294)
Better off to buy the right wheels or fitment that is. lots of stock or aftermarket available with tires. What wheels are on it now?
been using “adapters” (spacers that bolt to the studs and havenew studs for the wheel) from PE Motorwerks on that auction site for 5 years to make c6 base rims fit on my 85, 86, & 87 and no issues.
people use them all the time. lots of possible solutions for you. |
(Post 1598997732)
I was actually looking at a few sets and I didn't see any in 12mm or 1/2" with studs. I'll have to pull the wheel and see how much thread is there.
Originally Posted by pologreen1
(Post 1598997785)
I don't believe you will find a wheel with the proper offset to eliminate using spacers. I couldn't . Here's a link to a thread I started all about wheels and spacers.
https://www.corvetteforum.com/forums...9-5-tires.html |
(Post 1599003092)
Right now the car is wearing the stock 16" size tires on ARE wheels, 8" in front and 9" in the rear. The wheels are pitted and need to be refinished and that's not cost effective, I was quoted $100 a wheel. I plasti-dipped them in black for the time being and while it does look good, I still need tires as they are starting to dry rot. It makes no sense keeping the stock 16" as there is only one brand of tire in the stock size so I thought I'd go 17" to open up my options. I liked the look of the 35th Anniversary Camaro wheel, it's a Corvette style wheel but finished in a different way to stand out.
This thread is a few days old with many comments that very likely ain't relevant. You've only a WAG as to the wheels that you've interest in!!! If the wheels are actually 9" & 50mm they may actually be a 'better' fit than what you've got currently. and likely an appearance upgrade. You need to put your hands on the wheels and if maybe they're 'local' maybe do a 'trial fit' *** I believe you're correct in your assumption but I believe that even Cray if you're shopping for an early C4 considers 9" @ 50mm a fit. *** If you're interested in an 'actual' comparison pull one of your 8" and 9" ARE and compare whatever they are to whatever the '02 F-body wheels are. *** The 9.5 @ 38mm aren't actually relevant trying to compare current to the desired!! |
Originally Posted by WVZR-1
(Post 1599003425)
There's way to much BS going on in this thread. You mention having a 'line on' a set of wheels and then you speculate on what you 'THINK' is the offset! You mention comparisons to the original offsets and then mention that your current wheels are 2 X 8 and 2 X 9. The first thing you do is put your hands on the wheels that you've interest in and confirm the 'offset' I'd wager it's cast on the wheel back-side. You don't do a damn thing until you know what you've maybe got to consider.
Those will fit just fine.
(Post 1599039503)
.... I actually got 5 of them, newly powder coated silver too, for $150 ($30 each). All are GM wheels, 17x9 with 50mm offset .....
I never tried the Camaro SS wheels on my '85, but on the later ones they fit perfect. I have the earlier 5 spoke Camaro SS wheels on my '96 right now (with all four 275/40/17 tires). They look like stock on my CE. I like the later Camaro SS wheels also, but I haven't found any at that good of a price. |
