clutch Z bar question
https://i5.photobucket.com/albums/y1..._180921081.jpg
I went to start my Vette a while ago, and I heard a pop and the clutch pedal went to the floor. After looking at the linkage its obvious what happened. My question is, does it look like I can just put the special lock washer and nut back on and be good to go? To my novice eye, I don't see anything wrong. Im thinking the nut just backed off because I didn't stake the lock washer as stated in the AIM (which of course I will be sure to do now). Of course the lock washer and nut are nowhere to be found. I guessing they flew somewhere in the garage, but they're not on the floor under the car. |
You need one of these "lock" type washers for that end: I just picked the first vendor I saw. Follow the link and you can see some illustrations of how it is installed.
https://www.zip-corvette.com/63-81-c...ck-washer.html https://cimg9.ibsrv.net/gimg/www.cor...6141f20c8b.jpg
Originally Posted by C3 4ME
(Post 1598993661)
yeah, and they know me by name at Zip, as they're right up the street from me. I'll be there tomorrow picking that washer up.
:thumbs:
Originally Posted by carriljc
(Post 1598993873)
https://www.zip-corvette.com/63-81-c...ck-washer.html https://cimg9.ibsrv.net/gimg/www.cor...6141f20c8b.jpg Jebby |
Originally Posted by Jebbysan
(Post 1598998606)
Wow...learn something everyday.....
Jebby |
(Post 1598993873)
https://www.zip-corvette.com/63-81-c...ck-washer.html https://cimg9.ibsrv.net/gimg/www.cor...6141f20c8b.jpg Thanks for posting this. https://cimg4.ibsrv.net/gimg/www.cor...19e851eb3e.png |
Originally Posted by ignatz
(Post 1599007036)
I just went out and looked at my car and this "lock washer" is not there. Where it went I don't know as I am usually pretty careful about this stuff. What I also noticed is that there is nothing that seems to retain the felt washer and nothing seems to be indicated. It seems to be poking out of the shaft a bit. Shouldn't there be something there? Have a few things to take care of under the hood and will add this to the list.
(Post 1598993661)
Don't forget to "stake" the tabs.
Actually on mine I thought they were broken off so I put it off till "later" since I'd have to order that "special" staked lock-washer. I remained like that for at least 10 years till (mostly because I spaced it) I went back in last year to replace my pilot bearing. Amazingly enough everything was still tight (better lucky than good) and yet I was able to remove the old lockwasher and the tabs were actually still there... just had to tweak the part to make it usable again and then "restake" them to lock the nut with the support. |
(Post 1599021757)
I just use a long flat blade screwdriver inserted between the front of the brake booster and fender then give it a tap with a hammer to knock the tab flat against the nut face.
a Nylock nut is all I ever used...
I don't think I have a long enough flat blade to do that, but I'll give it a try. For now, I went back and backed the nut off and added loctite blue to the stud.
Originally Posted by CanadaGrant
(Post 1599022998)
Geez..... I didn't encounter much of an issue. I used either a long flat blade screwdriver, or a really short one. Lined it up with the tabs that needed bending/folding over and tapped them down with a hammer. I'm sorry I do not have more detail, but it was such a non-problem that I didn't ponder it very long. |
Just went and checked mine and yes lock washer is there but is on upside down ,the bottom right angle part is on the top . :willy: Put that on the list of things to do this weekend. :thumbs:
I'd like to add a few pix from my reinstallation that might be helpful to others. '67 L79 4-speed...
#1. Engine side seal, ball stud and bushing went in easily. Engine side ball stud with rubber bushing mounted to block. No pic. #2. Frame side first seal went in easily. https://cimg3.ibsrv.net/gimg/www.cor...3d9a8d08d7.jpg #3. Frame side second seal and ball stud went in easily. https://cimg8.ibsrv.net/gimg/www.cor...374a75dccf.jpg #4. Frame side spring went in easily, but, it seemed odd that there was no channel for it to lock into. Only held by friction? https://cimg8.ibsrv.net/gimg/www.cor...2dece20012.jpg #5. Frame side stud, fully seated, seemed too low in the z-bar. Less than 3/8". Maybe it's just my z-bar. https://cimg7.ibsrv.net/gimg/www.cor...d0bb304370.jpg #6. Frame side felt made it obvious something was not right. Again, maybe just my z-bar. https://cimg7.ibsrv.net/gimg/www.cor...4962e0362f.jpg #6. Frame side of my z-bar pre-grinder. 11 1/8" down to 10 7/8". And, it seemed kinda odd, the chamfer at the end. Almost to a point. https://cimg4.ibsrv.net/gimg/www.cor...82f4a6752e.jpg I'm guessing my 11 1/8" z-bar was the right length at some point. Maybe the engine shifted the extra 1/4" over the decades? And, I'm sure the right answer would have been to lift the engine, replace motor mounts, etc. I went with the 10 minute grinder path. With the 1/4" shortened z-bar everything fit and the frame side nut could be tightened. If this is a bubba fix, I can live with it. |
