-   Southern California (https://www.corvetteforum.com/forums/southern-california-45/)
-   -   Leather Dash Repair (https://www.corvetteforum.com/forums/southern-california/4249378-leather-dash-repair.html)
Yellow95 03-07-2019 01:21 PM
Leather Dash Repair
I live in OC and the leather on the dash of my '08 is pealing back and I want to get it fixed. Has anyone out there had this fixed, and if so, where?
It seems like this is a common problem with many cars, not only Corvettes.
The hard part of the fix is that the dash has to be removed to replace the leather.
Thanks
icyshark 04-07-2019 10:55 AM
Did you end up finding a place to do it? My 2009 has the same issue. I’m thinking of peeling the entire leather off. Any thoughts?
Yellow95 04-08-2019 10:16 PM
I have had no luck so far. I'm laid up right now. Will start looking in two months.
MTPZ06 04-10-2019 09:24 PM
Thanks
The other method is to R&R the windshield using a company like Safelite, etc. while its at an upholstery shop. Then its a simple re-glue for them with easy access to the dash.
zcobra1 04-27-2019 01:44 AM
Try Raul’s auto trim in Ontario.
Yellow95 04-30-2019 01:32 PM
Thanks for the suggestion.
I'm not getting around now, had both knees replaced.
I'll give them a ring.
SquareHead 06-06-2019 07:57 AM
Hey Folks,
Just an FYI, I had my dash pad removed and replaced at my local Chevrolet Dealer. Before I went to the dealership, I talked with several custom upholsterers in the area, and none of them wanted to touch it!
I also searched Ebay and other vendors for dash pad pricing.
I ended up paying $3,700 for the entire project, including dash pad, installation, etc.
The pad itself was $2,300.
Though it was a lot of money, it's now done.
I was very pleased with the work done at Cox Chevrolet in Bradenton, FL...
I am not connected with them, just wanted to pass on my experiences so it may help others.
Charlie
Wm.Hacker 07-30-2019 06:14 AM
Thanks
Be very careful who you use, just had my zr1 done and there is a spot that didn't even show problematic when it was repaired screwed up. Didn't last a week. Yes it looks much better but that one spot is really bothering me, sucks! We pulled the windshield. Do not us a shop that it's their first one, use a shop that have successfully don't several!
Tortugas12 01-22-2020 11:44 PM
I saw this thread and decided to go look at my car in the garage. Sure enough the batwing is starting to bubble and pull up by the HUD. I probably wouldn't have noticed if I didn't go looking for it but now it's going to bother me. Hopefully it doesn't get worse, the car is out of warranty so I'm SOL
joshp14 01-23-2020 10:26 PM
I didn't want the windshield removed so I pulled the dash out of mine a few weeks ago and had a local upholstery shop fix it for $80. It's really not too difficult to pull the dash panel.
https://cimg0.ibsrv.net/gimg/www.cor...094acd79d9.jpg
https://cimg7.ibsrv.net/gimg/www.cor...fc4d64ff7f.jpg
Yellow95 01-26-2020 06:42 PM
I had mine done at Auto Interiors of Mission Viejo. A couple of months into it it still looks great. Like the car above, they have to take everything apart and it looked like a bomb went off in it. All good now. It was about $1500. They seem to do a lot of them, they do all cars, not just Vettes. They all seem to have the same problem.
Yellow95 04-11-2020 12:22 AM
I don't know what kind of glue they used. Mine was not repaired, they remade a new one.
teds56 07-08-2020 12:13 PM
I'm curious ... what manual did you use or did you find a YouTube showing removal? Also how is the dash holding up so far?
teds56 07-08-2020 12:18 PM
Actually I'm looking at buying a 2014 Convertible red/ black interior with 3LT and the dash is showing signs of separating on the passenger side.
madmatt9471 07-09-2020 08:05 AM
This is good to know - :thumbs:
I will look them up - anyone in particular to speak to?
Thanks,Matt
Yellow95 07-10-2020 12:00 AM
Small shop. Only a couple of guys. I dealt with the owner, Luis.
https://cimg2.ibsrv.net/gimg/www.cor...721c0e6ea4.jpg
madmatt9471 07-10-2020 07:49 AM
Thank you very much!
Thanks,Matt
rik8020 10-25-2020 11:53 AM
Leather Dash
Thanks
I am replying to your message on the dash. I also have an 08 4LT and live in the OC and having this problem. Did you remedy your problem? I have looked at the Krewal tutorial to remove the dash but it goes beyond what I personally want to do. Any help is appreciated. Rik
Yellow95 10-27-2020 11:52 PM
I had it repaired at Interiors of Mission Viejo. See above.
I you want to see it, We can get together.
whalepirot 10-28-2020 10:58 PM
Originally Posted by berniet (Post 1601296621)
Sir what glue did the repair person use.
Being a near universal self doer, I have some experience with fabric glues, preferring 3M, but know that the pros have access to non-commercial products, as it the case with virtually any repair, plumbing, detailing or whatever.
This is a challenging environment, with sun thru the glass. Even if a great glue is used, smoothing the applique requires some skil (experience) and perhaps some special tools. I ALWAYS use a folding dash screen inside all my cars parked in the sun, even if < an hour.
