Oil at Fuel Pump
My original 4657 63 fuel pump has oil smeared all over the bottom, I've cleaned it up and will run the car tomorrow on the lift and look for the source... Two questions:
Could it be the mounting bolts (loose) or gasket ? If not I have to think its the oil seal on the diaphragm rod; in which case its a rebuild... I haven't done one in 6-7 years so -- who has the best kit going right now ? Ethanol resistant and good parts are imperative... |
Don't drip oil on the T-Bird.
Originally Posted by MikeM
(Post 1599006908)
Had this happen on my 69 Camaro recently. Changed the gasket and problem went away. Hopefully it’s that simple for you as well.
Ed |
Not so lucky -- the fuel pump is leaking oil around the perimeter screws at the diaphragm - ordered rebuild kit.
Either diaphragm or oil seal failed internally... I'll have to rebuild it as its an original 4657 "no frog pad" 63-only fuel pump... |
Frank,
When you overhaul the pump broach the surfaces with a flat surface and 220 wet sandpaper. |
Will do....this pump had given me 3 years good service since I installed it prior to regional judging....
I just hope the modern rebuild kits are decent.... I went with a Zip kit.. |
buy a new pump there cheap carter only:thumbs:
Originally Posted by reno stallion
(Post 1599016101)
Originally Posted by Frankie the Fink
(Post 1599006623)
Could it be the mounting bolts (loose) or gasket ? |
(Post 1599013201)
I just hope the modern rebuild kits are decent.... I went with a Zip kit.. Dan |
(Post 1599010906)
Either diaphragm or oil seal failed internally... I'll have to rebuild it as its an original 4657 "no frog pad" 63-only fuel pump... Verne |
Originally Posted by W Guy
(Post 1599017147)
The last one I have recorded without the screw pads is dated Dec '63, so that type is also correct for early '64s. (and prior to '63). When you take it off, I'd like to get the date from you and a few other details. I'll send you an email.
Verne |
Originally Posted by dplotkin
(Post 1599016930)
Had I seen this in time I'd have said call Arthur Gould in NY (well known for water & fuel pumps) what you should use. You may still want to call him & explain what you have to get his take.
Dan I'm pretty sure Arthur isn't in NY any more. Check Hemmings for his ad and his current location. Verne |
(Post 1599017194)
Dan,
I'm pretty sure Arthur isn't in NY any more. Check Hemmings for his ad and his current location. Verne See: http://arthurgouldrebuilders.com/ Dan |
(Post 1599006908)
Originally Posted by Willcox Corvette
(Post 1599018784)
What's a T-bird Mike... :lol: ... :D
To catch Ernie up....
I got the wife a pristine one owner 2002 T-Bird "premium" 2 top car with less than 20,000 miles on it for Valentine's Day. A day that will live in infamy. I had no idea the car was so polarizing....some love it, some despise it. No middle ground it seems.. One Corvette buddy calls it the "Valentine's Day Massacre" but the wife calls it: https://cimg0.ibsrv.net/gimg/www.cor...a0b9e5528f.jpg |
(Post 1599019875)
(Post 1599019756)
Looks like you've missed a thread or two here Ernie. :D
E |
(Post 1599020506)
Mike I know you have a soft spot for the big blue oval....lol.. E |
