New PAC interface ?
I just came across this on PAC's web site, I've never seen it before. Is this something new that's going to replace the RP5-GM11 ? Does anyone have any info or tried one of these ? https://pac-audio.com/catalog/radiop...faces/gm1a-rst
I've seen that also and have been wondering about it also. I am about to replace my stock head unit in my C6 Z06 and am planning on using this interface. Please let us know if anyone has used this new interface.
Originally Posted by chandretti15
(Post 1599019063)
I have to say it does look interesting, it allows for more adjustability than the old RP5-GM11. It allows you to hook a computer to it and use the RadioPRO PC App to do the following:
• Configure User Interface Options such as: • Factory amplifier settings (Bass, Mid, Treble, Gain,Fader and Balance) . Chime Volume . Camera Settings • Telematics Volume . Update Product Firmware • Read Firmware/Hardware Versions It'll be interesting to hear from someone who tries it, I'm tempted to get one and try it out, but it's hard for me to justify the $280 for it when I already have the RP5-GM11 installed in my Vette |
Madsonp, I haven't seen any reviews on that model yet, so I am holding off making any judgement just yet. Hopefully they have improved on some of the Pac RP5-GM11's shortcoming. Like difficulties programming the steering wheel controls, most notably the phone answer and end buttons, and also hopefully improving the sound of the warning chimes by making it more adjustable and less irritating. Other than that, I don't see much more benefit to C6 owners IMO if you already have the RP5. Having the warning chimes go through the cars speakers could be a nice improvement but most of the other features don't really appeal to me. For instance, adjusting the bass/mid/treble/fader/balance through the interface seems like overkill and unnecessary when I can make those adjustments through the head unit. Also the price of $280 should be a lot less when you start finding it available in more places. If you notice, PAC has the RP5 listed for $230 but you can find it in most places online for under $100. But if I was installing a head unit today, it might be worth a try but only if I can find it for much less than the full retail price listed on Pac's site.
I think this is what you want?
https://pac-audio.com/catalog/amppro...faces/ap4-gm61 |
Originally Posted by TorchRedFred
(Post 1599022448)
Originally Posted by Matthewstorm
(Post 1599027706)
(Post 1599027706)
Originally Posted by madsonp
(Post 1599029484)
Were you ever able to get the phone answer and end buttons working with your RP5 ?
(Post 1599029921)
I got one of them programmed, I forgot if it was answer or end since I never use them. I'm not sure if it was from lack of effort on my part since I spent very little time on it and kept saying I would get it programmed next time I had the radio out. I have since taken the head unit out again to do another upgrade put never bothered to try again. But I have heard others have had difficulties getting both buttons programmed and have called Pac and tried multiple times with no success. Others claim that they got it to work, so it might depend on what firmware your interface came with. I know you can update the firmware but it wasn't worth the effort to me unless I know for sure it would work. I've seen posts where some have said they successfully switched to the RP4 to get the phone answer/end buttons to work and had no issue with the programming. The RP5 is more popular, but if OnStar is not important, then the RP4 may be a better choice for most for that reason.
Well, believe it or not I came across one of these on an internet auction site with a starting bid of $10 and I figure what that heck, so I bid on it and got it for $10. So when it comes in the mail I think I'll pull my RP5-GM11 out and give it a try. The thing I like about the looks GM1A-RST is that it looks more compact so I'm thinking it'll fit in there much better. I'll report back when I get it installed to let everyone know what I think of it.
(Post 1599040192)
Well, believe it or not I came across one of these on an internet auction site with a starting bid of $10 and I figure what that heck, so I bid on it and got it for $10. So when it comes in the mail I think I'll pull my RP5-GM11 out and give it a try. The thing I like about the looks GM1A-RST is that it looks more compact so I'm thinking it's fit in there much better. I'll report back when I get it installed to let everyone know what I think of it.
(Post 1599040758)
What? You got it for $10? That's too funny, but a score also. :rock:
https://cimg8.ibsrv.net/gimg/www.cor...080b4354ec.png |
Received the interface today, and it was just as they advertised it, brand new and factory sealed packaging. I have a spare harness for my head unit already, so all's I got to do is solder the harnesses together and swap it out with the RP5. It'll be a couple days before I can get to it though, so stay tuned.
Well, I got the new GM1A-RST all soldered up and ready to install, just waiting for it to warm up a bit here, then I'll pull the RP5 out and plug the new one in and try it out. Hopefully I'll get it put in today or tomorrow.
I got the GM1A-RST installed and here's my review of the unit.
Pro's The unit has the chimes through the stock speakers instead of needing the chime module that comes with the RP5-GM11. The exception to this is if you have a standard Bose system (no factory amplifier) or you connect a aftermarket amplifier to the factory speakers. In this case you have to use the chime speaker that comes with the unit. Con's The chime speaker that comes with the interface in my opinion is ridiculously large, it's about 2" square and 1" thick. Pro's I feel they've improved the steering wheel control programming sequence with multiple LED's and chimes to tell you what mode you're in. There's different options and its well explained. I was able to program the end call button on my steering wheel. Con's I still haven't been able to program answer call button on my steering wheel, no matter what I've tried so far, it activates Onstar, but all the other buttons on my steering wheel function correctly. Con's I was hoping the interface was going to be smaller than the RP5-GM11, I'm sorry to say though it's narrower than the RP5, it's longer, so it's probably about the same cubic inches size wise as the RP5, so when installing it in the Corvette, it's still like stuffing 10 pounds of crap in a five pound bag. Pro's You can connect the unit to a computer and change some of the parameters and up-date the interface using the Radio Pro PC App that you download from PAC. Con's So far I haven't been successful, in connecting to the up-date app I downloaded from PAC so I haven't been able to change any of the parameters or perform up-dates. I sent a note to tech support asking about this but I have yet to hear back from them. There maybe a possibility that up-dating the unit might be able to address the phone answer button I mentioned earlier, but I don't know this for sure. Final notes So there you have it, in my opinion if you already the RP5, it's not worth it to change it out with this one, if I didn't luck out and get it for $10 bucks like I did I never would have bought it unless my RP5 quit working. If you're buying an interface for the first time or needing to replace your RP5, it might be worth giving a shot. I plan on playing around with it some more and hopefully I'll get it to connect to the app. If I figure out more on it I'll be sure to do a follow-up post. |
Thanks for all the feedback on this unit. I am picking one up today to go with my install into my ‘09 Z06. I am installing an Alpine iLX-W650. I was fortunate enough to get one of the fist 2 units shipped to my local dealer.
(Post 1599095393)
I got it put together and plugged it in briefly. Radio and chimes work. Rear camera works. That’s all I had time for and I had to get going. Will get back to you on the PC app.
I have an ‘09 Z06 with Bose. It’s a 2LZ with a non nav 6 CD radio. I may have plugged in connector 3 to the non amplified port. But I think it’s supposed be in the amplified port, correct?? I wouldn’t have damaged anything by doing this right? |
