Anyone with big builds or even smaller have this problem with Brisk or other Plugs?
I had them on my 2014 Z51 car with long tubes and knn cai. After a lil while, I chunked them and went back with NGK. I lost a couple mph in the 1/4 mile. Depending on your build, you might of not had a cold enough plug. What was it gapped at?
Yikes! Among other options, either you had some serious timing issue or the plugs are way toooooo hot! :ack: DON'T do again what you did here!
Think they were gapped too big at .30. I got them down to .25 holley and hp tuner logs showing misfires gone. I have one step colder I may go two steps once I get a bit more logging done and sent to my tuner Chris Crawford. Will report back.
I just ditched my Brisks in favour of NGK's. I started getting misfires, then my engine sounded like a Subaru. Tracked it down to one cylinder not getting any spark at all - laser thermometer read 70c on #6 and 300c+ on all other cylinders. I swapped everything before I did the plug, nothing fixed it. Swapped the plug and it was instantly fixed.
Annoyingly I dropped the plug straight out the bottom of the car and down a drain before I could inspect it :toetap: |
