85 vacuum line wiring diagram for under the plenum
All right after two bolts on the plenty and which were seized I took the plenum passenger side runner off almost got the fuel rail out but one of the two torx bolts a strip and stuck in the bottom part of the bracket all that being said I've managed to snap every black plastic vacuum line under the plenum, from the EGR to the system up front is anybody have a diagram drawing pictures so when I put this back together I'm not scratching my head for a year LOl
This is the 88/89 diagram. Hope this helps some. Try You Tube and also Google for more.
https://cimg8.ibsrv.net/gimg/www.cor...74f8208ef8.jpg |
hey thanks for the schematics, i did take some pic, for a change, so that is a start, as soon as i get that damn bolt out of the fuel line bracket i can start finish , and to think it was only a injector swap, anybody know of a cheaper way to replace the coolant bypass hose
and luckily its only all the plastic lines under the plenum...lmao, whos bright idea to use A) plastic vacum lines, and B0 torx bolts
