Need advice please
My 65 convertible 327 300 hp has the sloppiest shifter I have ever used.
I know I can get a rebuild kit but wonder if the 4 speed trans has to be removed in order to remover the oe shifter itself. |
no need to remove the trans it self. under car exhaust makes it a tad harder but its doable
(Post 1599028705)
Is it the original Muncie transmission and shifter ?
Many shifters were swapped out for aftermarket pieces over the years....my 63 has a Hurst shifter in it, even has a fake reverse lock out.... |
Not fun for someone with big hands, especially the Jesus Clip R&R. I would recommend unbolting the transmission mount to let you slide the tranny to the passenger's side an inch or so. Space is at a premium when trying to remove and reinstall the shifter.
Ron |
I found this article helpful when I did mine:
http://www.corvettemagazine.com/tech...ifter-rebuild/ |
Originally Posted by Frankie the Fink
(Post 1599030455)
Many shifters were swapped out for aftermarket pieces over the years....my 63 has a Hurst shifter in it, even has a fake reverse lock out.... BH |
My 65 has an original GM Corvette factory shifter and it feels great. Have it set for short throw shifts. It came with the car when I bought it in 1993. I cleaned it up, lubed it good, installed it, adjusted it using the correct washers and clips. I've had many Hurst shifters over the years in various cars and wouldn't change mine out for one. Maybe mine is a rare one that isn't worn out, I don't know but it sure feels tight.
I think possibly that over the years shifter parts and pieces get changed out like the rods, the shifter arms on the trans and maybe being out of adjustment that makes the factory shifter just feel bad, loose or worn out when really it may be a mismatch or incorrect install of parts. |
(Post 1599030455)
Dan |
w/Jmoore. They work fine when refreshed, your call
The old Hurts supershifters were awesome. I still cant stand the feel of a T56 or similar trans even with the best shifters out there, esp when shifting fast. |
The rebuild kits for the OEM Muncie shifters are easily available from most of the vendors and I had a blast rebuilding mine ! Check the main chrome stalk and make sure that it hasn't separated at the base, a quick weld can take care of that. You can make that "clunk-clunk" shifter of yours as good as new. :thumbs:
Ray |
1 Attachment(s)
Here's a feature article I wrote a while back on rebuilding the Muncie shifter. :thumbs:
Okay, not trying to heist the thread, but my "T" bar on a stock shifter and stock BW trans slides up and down easily and rattles when driving if you don't hold it. Is there a fix for this. IIRC, this "T" is supposed to be attached to a spring or something. Car shifts into reverse very easily.
Originally Posted by 62cruiseer
(Post 1599036445)
And how do you like the Hurst installation with the fake shifter Frankie? Seems to be the best of both worlds to me and something I thought about with the other car. The linkage on the BW trans in this new car is a loose as well, but shifts very smoothly, so it would be nice to tighten it up and maybe shorten the pattern.
BH Now, I put a new, upgraded side cover on the Muncie with new rooster combs and bearings for the shifter forks and that certainly helps... It actually passed ops judging too, of course you have to work the fake lock out when shifting.... One of those "they didn't ask, and I didn't tell" things. I wouldn't swap back to an original shifter at this point... |
(Post 1599042169)
(Post 1599042442)
place a rubber O-ring under the T handle and shifter base
Bh |
When I bought my '65 three years ago, the first thing I replaced was my sloppy shifter. I sold the old one one E-bay ($ 140). Bought a new original style one from a vendor. My son and I had it installed within 3 hours. Already had the console out to be painted. Easy install. Good luck, Sully
