Reprograming 2018 C7 computer
Purchased a AFE Cold Air Intake for my Z06 A8 and took it to the dealer to get an estimate on how much it would cost to get it installed. Prior to the service rep giving me the quote he said, let me give this after market shop a call to see how much it would be to have them CPU reprogrammed. When he spoke directly to the programmer and they told him that there a lock on the system and there wasn't anything on the market to reprogram the 2018 CPU yet, if you tried your unit would start throwing codes and eventually not work. This is a very reputable shop and has done many Vettes, has anyone heard of this?
Originally Posted by kazoo794
(Post 1599033040)
LT and ST fuel trims should be able to compensate , if you really want a tune then you can use a handheld and do a mail order tune for the AFE , The Diablo I3 actually comes with and AFE CAI tune built into it or call Doug at ECS Unless you use the Diablo , any tune is going to void your warranty .... Dave |
I have a life time warranty on my engine, my service manager and I was talking about what would void the warranty and discussing the long tube headers, x pipe and exhaust. He told me that none of that would void my warranty and as long as I don't go into the engine. Although I was only talking about getting the cold air intake installed only I guess he thought I wanted the whole deal installed. That is probably why he talked against it and said it couldn't be done. Being it was late on the east coast, I called West Coast Corvettes and talked with them. They told me that I didn't need a tune with an AFE Cold Air Intake. I will also call ECS tomorrow for a second opinion, they have tuned my vettes before.
I can assure you that unless you are using the GM CAI and GM Tune that goes with it , that any other tune will void your warranty. Not sure what your service manager is saying ...
What kind of warranty is lifetime ....... Dave |
Originally Posted by Dcasole
(Post 1599033123)
Up to 2016 nothing has to be done to program an ECM starting in 2017 to 2018 they ECM is locked and requires 2 credits to unlock but it can be programmed .... What makes you think that you need a tune with an AFE , do you have a CEL
Originally Posted by 6Speeder
(Post 1599036642)
LT and ST fuel trims WILL compensate during closed loop operation. They WILL NOT compensate during open loop (WOT).
Dave |
(Post 1599036788)
You are correct but WOT on a factory tune is very rich anyway and will not cause an issue when installing just a CAI ....
Dave |
2 Attachment(s)
As you can see, my factory ALL STOCK tune commanded a 12.4 AFR until COT kicks in at about 5,000 rpm, the blue line. But with a CAI it ran a bit leaner and didn't go into COT until higher in rpm, the red line.
(Post 1599035747)
(Post 1599037533)
When I purchased the car, the engine was warranted as long as no mods were made to the engine internals
(Post 1599037022)
It is on an LT4 when it goes into COT, not before that. I can't say about the LT1 tune. Still, making a blanket statement that the LT and ST will compensate may make some folks think they will make up all problems.
Dave ... |
Thanks, that's exactly what I needed to know. I am just going to install the CAI
(Post 1599039374)
I think the blanket statement is accurate but ....OK so I should have clarified , LT and ST fuel trims will make up for any lean condition at anything below WOT and at WOT while you will be a bit leaner you still will not be in a danger zone ........
Dave ... To the OP: Get your car on a dyno stock. Then when you change something, dyno again. That will ensure you are still safe (or not :() and will show that the part actually made more power. I have taken my car from 580 SAE to 730 SAE with my mods. I checked it (on the same dyno, because they will all read differently) after every mod, now I run a wideband continuously for safety. |
(Post 1599035747)
I have a 2018 GS, I bought a tuner from Diablo, This car cant be tuned be the regular guy. Trying to return the device
(Post 1599035747)
Originally Posted by John Harry
(Post 1599045633)
The only thing that matters is what the warranty says in writing.
Dave |
No problem I decided I am not going to do any type of retuning, just going to add my CAI and cruise. Maybe get on it a time or two!! :D
(Post 1599046020)
Right and a aftermarket tune violates any engine warranty ... even if the dealer is a progressive thinking dealer its GM who has to approve the warranty . When my motor dropped a valve the first thing that was checked was my VCN file .......
Dave |
Originally Posted by vetten76
(Post 1599075096)
You dropped a valve on your C7? I thought that was a c6, 427 thing. Bummer.
Dave |
