Heads/Cam Z Low Dyno/Not Taking Timing
I just wanted to get some feedback/see if anyone has had any similar issues after a cam install
I picked up the car with AHP stage 4 heads, ported and milled .010, BTR dual valve springs, CHE rocker arm, Ferrea valves, LS7 lifters, etc. as well as supporting bolt ons, ARH longtubes/cats pipe, borla atak exhaust, and haltech intake. Everything was done at AHP by previous owner and the car ran pretty strong. The only change that was made was a BTR Stage 3 cam and length of pushrods Car goes to dynojet and lays down 517 to wheels at 19 degrees of timing. It would not take any more timing past that as it made that same power at 23 degrees and even at 27. See attached graph for curve (red line) https://cimg3.ibsrv.net/gimg/www.cor...ed95255260.jpg I wouldn't be concerned with the dyno numbers if the tuner didn't mention that was the lowest heads/cam Z he had seen. He mentioned that the car did not "rev" like comparable Z's that he's ran on the dyno and that is felt like it labored through the gears but I don't necessarily have anything myself to compare to coming from a stock cam previously. Just worth mentioning in terms of anyone possibly experiencing anything similar after their cam. Another concern was that he had issues tuning out ignition/spark and getting the car to start up consistently has seemingly been impossible on two separate sessions. The car fires right up when cold however any start up after that requires giving it a touch of gas to get it going and it diesels on shut off. Troubleshooting that has happened so far: - Compression Check was 205 on all cylinders - Vaccum test - Heat gun the cats to check for restrictions - Dyno pull with the intake removed to check for restrictions - Checked battery (for possible start issue) and tested out good Appreciate any feedback |
Sounds like who ever installed your btr 3 cam installed it a tooth off (not dot to dot).
Installing a cam a tooth off on one of these cars will exhibit the exact symptoms (low timing, power, starting issues, ect...) that you describe above. It will start run and drive but will act just like you describe. Pull the timing cover and verify cam gear and crank gear dot locations because it sure sounds like your a tooth off. https://www.americanheritageperformance.com/ |
Originally Posted by American Heritage
(Post 1599036134)
Installing a cam a tooth off on one of these cars will exhibit the exact symptoms (low timing, power, starting issues, ect...) that you describe above. It will start run and drive but will act just like you describe. Pull the timing cover and verify cam gear and crank gear dot locations because it sure sounds like your a tooth off. https://www.americanheritageperformance.com/ Thanks for the response. I installed the cam and made sure it was dot to dot but I could be wrong. However, wouldn’t that trigger a P0016 cam correlation code? Car doesn’t trigger any code at this time. Faulty cam sensor maybe? |
Did you degree the cam? Possible that the cam could have been ground slightly off, similar to being a tooth off
Originally Posted by Buddy A
(Post 1599040264)
Do you have a broken spring or weak springs - how old are the springs (maybe spring broke on dyno). Were the springs changed at time of new cam install? Another thing might be is the preload, but I see you did new pushrods so I assume that was done correctly. Is the intake valve titanium - you just say Ferrea valves? One thing on running the steel intake valve is a regular dual spring may not be enough for the higher rpms though I am not sure that is causing you to be down on power. I know on the BTR website they say if you are running heavier stuff use xyz spring which is about 40 pounds heavier on the nose. Your graph looks normal in shape just the numbers are low and it does appear to drop off after 6,000 rpm pretty good. You have very good compression.
Sounds familiar installed aftermarket heads and llsr cam on an ls3 made 450/500hp would not take any more than 17 degrees at wide open throttle went to the track and run 10.5/10.4 all day a6 car.
Originally Posted by double06
(Post 1599042482)
I made about 550whp with fixed/ported heads, long tubes, stock intake manifold, halltech intake, and a BTR Stage 3 cam. AHP wouldn't be my first choice for head work, IMO.
Originally Posted by jayyyw
(Post 1599074119)
Which type of dyno and do you know what timing advance your tune has at WOT? |
Originally Posted by MURDEREDOUT
(Post 1599075598)
Thanks for the reply!
Cool thanks for the info! What stumps me is that it makes the same power with more timing and still zero Knock. (Knock sensors were not desensitized)
Try to rig up a degree wheel to see if its a tooth off. Shouldnt be too hard if you are creative.
You've either got a cam timing issue, bad springs or it's in the heads; all this assuming the tuner is competent. I had Frankenstein heads and had the same issue.
How much preload do you have on your lifters? Too much can limit the top end (or so I've read). Last night, I changed to a shorter push rod on my LS3 heads/cam build. Mine was peaking at 6200 and I thought it should peak higher than that. The tuner set the red line at 6800. The streets were wet this morning so I couldn't run it hard. You could feel it run out of breath at 6200 before. We'll see.
Too much preload on the lifters and it will be down on power because it won't want to rev I believe
Originally Posted by Millenium Z06
(Post 1599187536)
Well, mine now pulls clean to rev limit after the shorter push rods installed. Not saying that it's a slam dunk that that's your problem. It's easy to check the preload though. Pull a valve cover off and locate a cylinder that has a valve wide open. The other valve is on the base circle. Back the rocker arm bolt off on that one until you can just wiggle the push rod. Now, tighten it up to 22'lbs counting the turns it takes to get there. If it's a whole lot more than one turn, you could probably use a shorter push rod. If you don't have good control of the valve train, timing doesn't matter.
I know the purists will get their diques bent doing it like that. That will get you in the ballpark though. Get you an adjustable length pushrod, a dial indicator, a white smock, and a pocket protector full of pens if you'd rather.... |
Old Motörhead.
Glad you figured out your issue. I’m aware of the valvetrain set up on where it can affect power. Still wouldn’t affect how it only takes 19 degrees of timing advance. But I have a feeling it’s .030 milled vs the .010 milled and I’m not taking out the heads to measure and CC of the heads. How much shorter push rods did you use or need? Did you feel or dyno the difference? |
19 deg is fine...especially with higher compression and near sea level pressures.
