MSD Blaster 2 coil
Anyone know the resistance readings for a MSD Blaster 2 coil? I noticed mine to be getting fairly hot after just a quick turn on. You can touch it but not for very long. You can bench test these for resistance and it should be within a real close value of what the spec calls out. thx
Idk but I know a while back they had problems with that unit
MSD Blaster 2 web page. Just click on SPECS tab.
https://www.holley.com/products/igni...eet/parts/8202 I had a Blaster SS just fail one day less than a mile from home. Had a spare out the house and had wife run it out to me. Now I keep the spare in the car. LOL. |
if its new bring it back
Resistance is futile. Go get a NAPA coil and be happy.
Here's the problems I had with a MSD Blaster 2 AND an Acell coil:https://www.corvetteforum.com/forums...ion-coils.html
What ignition are you running?
Jebby |
Originally Posted by Jebbysan
(Post 1599045005)
Jebby |
Pertronix has told me to keep the 12 volts on the coil just run a ballast resistor in series with it...... Will that keep the coil from over charging? I'd feel safer using a magnetic ring in the distributor which what they later changed it to using. I have the original version apparently. Hmmmm
Originally Posted by CiCiC3
(Post 1599050093)
https://cimg2.ibsrv.net/gimg/www.cor...f38d67acde.jpg I think this is the unit you have if it is a converted points unit......either 1181 or 1181ls (lobe sensing) You only need a ballast resistor if you use the 1.5ohm coil......I would buy their coil and run it without personally....less wiring and "stuff". Jebby |
https://cimg1.ibsrv.net/gimg/www.cor...d87e37f75d.jpg
This is the ballast for the MSD POS. Good luck. |
Use a good Napa coil youre better off. The other has had a bad rep since day 1
(Post 1599050323)
https://cimg1.ibsrv.net/gimg/www.cor...cb9b630b8d.jpg
