ZR1 wing
i just bought a 2018 zo6 carbon 65 edition with the zo7 package
I'm going to mostly track the car.can you install the zr1 wing on the zo6 and is it worth it thanks |
Welcome, car sounds good. Post some pics!
Moved to C7 Z06 Discussion.
yes you can add the zr1 wing. a metal bracket is hidden behind the rear fascia of the car. This bracket first has to be installed. From there, 2 small holes have to be cut in the top of your rear fascia, for the bracket to exit up through, and for the wing to mount to.
There are aftermarket companies who sell nearly identical wings for MUCH less money than GM sells them for. But just understand either way you are talking over 3 grand if im not mistaken. GM OEM is more than 6 or 7 grand I think. |
You can also plan on adding a shit ton of front aero to balance the wing and stabile the car
Thanks
The car came with the front carbon splitter with the wings on the side it looks like the one on the zr1 |
^^^No not really. The ZR wing will create more downforce than the Z07 stage 3. It will need to be balanced up front. While your Z07 may look similar the ZR has additional front aero, there is a significant difference.
I found this on the Weapon-X site earlier today:
https://weaponxmotorsports.com/colle...14359531618353 |
Originally Posted by TXshaggy
(Post 1599042550)
The ZR1 aero is not Viper ACR-E territory. The addition of the rear wing and front spoiler was a marginal improvement over what was already on the car. |
^^^Lots of discussion on this...I’ll leave it up to your google skills to satisfy your curiosity. Perhaps you can post on the C7 ZR forum for additional.
The ZR generates 1000lbs of downforce at speed, this is about twice Z07. One advancement is “Corvette first, ZR1 borrows front underwing technology from the race car world to turn its closeout panel into a downforce control surface.” There are other control mechanisms. Bottomline, you can’t double the downforce on the back without front consideration. |
Is it worth it?
I am going with no. The car as design is nicely balanced. Is has appropriate downforce/drag for its power.
I believe there are better places to spend money. |
awesome
i appreciate every ones response thanks for the helpful information ill post pics of car soon thanks |
At the very least add some front dive planes (carbon fiber). Real carbon ones go for $400 to $600. ZL1 1LE has them, Viper ACR, they work but as others said it's about car balance so get to know your car well on the track, FIRST. Then adjust. What I am doing anyway instead of jumping before I look.
we need a thread that gathers all the potential c7 dive plane options, i need this answer myself...
Edit... its created now... https://www.corvetteforum.com/forums...ns-thread.html I too strongly agree that the zr1 is light in the nose from an aero standpoint vs the large wing in the back. It then dawned on me, that since the extra coolers are in the front of the zr1 and the extra weight of the lt5 heavy heavy blower, i realized, the zr1 without a wing was front heavy... so the wing kind of cancels that out at 80mph, but as the car gets into higher and higher speeds, it becomes light on the nose i believe, relative to the back of the car. Poorsha would be the one to ask about this i suppose. Anyway... the point of the story was a z06 or grand sport with the big wing on on the back would be more light in the nose than a zr1, so dive planes would be needed to keep the car well balanced. A regular front splitter alone is not going to keep up with that park bench on the back of the car |
(Post 1599043982)
The ZR generates 1000lbs of downforce at speed, this is about twice Z07. One advancement is “Corvette first, ZR1 borrows front underwing technology from the race car world to turn its closeout panel into a downforce control surface.” There are other control mechanisms. Bottomline, you can’t double the downforce on the back without front consideration. I know most wings can’t generate even 800 lbs at 150 mph, and it’s not even close. ZR1 isn’t al that big or aggressive. Dual elements are needed for that kind of crazy down force you are talking about. It is is very misleading to boast a number vs Z07 aero of Z06. Benefits of wings are not solely due to max down force. But it is often 10 to 1 ratio of down force and drag (for a proper wing) vs 4 to one of the barn door or we call it wickerbill. Also, downforce can be finely adjusted with a proper wing. Angle-of-attacks carries the downforce greatly. So driver can adjust to their liking. |
^^^^Use your google fu on chevy press release.
(Post 1599047249)
Before 3D scanned to generate any datas... I can almost for certain that 950 lbs or 1000 lbs of down force in some publications is at top speed. That wing is very mild by fixed aero standards. |
Yes likely at speed...believe that goes without saying.
(Post 1599047363)
The mild chasis mount wing I offer for C7 is at 400 lbs alone at 150mph, calculated from 3D scans and software simulations. |
Just to add to the insanity of screwing around with the GM engineering force . . . I have a ZR1 with the ZTK package. . . since I am height challenged, I would like to switch the spoiler to the non-ZTK version (low) so that I have a better view at the losers in the rear view mirror . . . any thought about the 'balance' of the car with the lower wing would be appreciated. I love the handling and have driven at the Las Vegas track . . . would the change make an appreciable difference?
Thanks, Cliff |
