Replacing worn brake pads
What method are members using to compress the caliper pistons in order to get new pads to slide into place? Can it be done without removing the caliper?
Iron rotors? Just your hands, or if a little tough use a big wrench or screw driver. You can use the old rotor backing plate to get all pistons at once.
There are plenty of tools, I own a few, but this is the easiest method. |
Originally Posted by hebegb
(Post 1599044550)
