Advice on mods list of possible Z06 purchase
I'm looking to pick up a C6Z and found one with the following mod list in the ad. Says there's more parts and this is just a quick list. Assuming it was put together properly does this sound like a reasonable build list ? Will be a street driven car for me, some track days , no drag racing.
With the specs provided , does the cam sound streetable or would it be subject to surge when cruising through the parking lot etc? Anything to ask the seller if/when I make contact ? - Center force twin disc clutch - New timing set - Custom dyno tune - CNC ported ls7 heads hand finished including titanium intake values and stainless exhaust values, double springs, titanium retainers - Custom hyd roller camshaft 226/239 @.050 - Caddy high rev gm lifters - Chrome molly push rod kit - MLS head gaskets - ARP head fasteners - Fast intake - Fast fuel rail kit - Stainless works headers and x- pipe kit with high flow cats - K+N cold air kit |
Sounds like a good start. What size are the headers, what is the lift and lobe separation on the cam, does it have a 102 throttle body. How much $ and mileage?
If the tuner was good it should drive well.
Don't have more technical details, that's what was listed.
My guess is that it could drive pretty well. I have a 246/258 @ 0.050 and Pat G got it running real nice. 24 degrees of overlap. I can idle through a parking lot smoothly. I have more cubes though
