Corvette power-steering recall affects 27,000 cars
Good luck to those 2017 owners affected by the recall. Just glad it is not for the 2014 model year.
^^^ +1
Holy crap.
It sounds like the steering rack will be replaced. So that means front end alignment also. Lots of work. |
This happened to me as I was about to leave Kerbeck's with a new '17 in Sept. of that year. Contrary to the article linked to above, there was NO indication of a problem on the dash or otherwise... just no ps.
To Kerbeck's credit, they had an identical '18 they redid the paperwork for so I could still get on the road (1500 mile trip home) in a timely fashion, for the same price. Minus 1 for GM, plus 1 for Kerbeck! :yesnod: :thumbs: |
Sounds like its a control board. Why would the steering rack need to be replaced? Different sensor for the board? Or just all one piece?
Looks like it affects 6,259 vettes. How do we check? Call the dealer? |
Originally Posted by PatternDayTrader
(Post 1599046928)
Holy crap.
It sounds like the steering rack will be replaced. So that means front end alignment also. Lots of work. Bill |
(Post 1599047010)
Looking at the service manual instructions they don't do anything to change front camber or caster so all they have to do is reset front toe when the car is back together. Not a big deal as long as you know what the toe was before they started the job.
Bill In practice though, the dealer tech and service department will be blamed for all subsequent alignment related problems. Imagine you do this job, then set the car up on the alignment rack, and everything is out of whack but you only adjust the toe setting. |
Mine is part of the recall, but it seems that so far they don't have any parts so i'll just wait. So far the car is fine.
Originally Posted by Aramis76
(Post 1599047098)
(Post 1599047098)
According to this article... https://www.consumerreports.org/car-...ering-problem/
It affects Corvettes manufactured between these dates. “2017 Chevrolet Corvette coupes manufactured from July 27, 2016 through May 4, 2017” |
Ran my VIN says its not included in the recall.:toetap:
Where did you run your VIN?
(Post 1599046928)
Holy crap.
It sounds like the steering rack will be replaced. So that means front end alignment also. Lots of work. “GM says the problem stems from defective control boards for the Bosch-supplied electric power-steering system.” |
Originally Posted by C7 Marc
(Post 1599047391)
Originally Posted by Maxie2U
(Post 1599047452)
Where did you come up with that?
Vin
(Post 1599047391)
Originally Posted by shineocd
(Post 1599047607)
The link in post 12 or 16 will work. I tried both and both said no recall for my VIN.
(Post 1599047232)
It affects Corvettes manufactured between these dates. “2017 Chevrolet Corvette coupes manufactured from July 27, 2016 through May 4, 2017” :confused: |
