2014 Front Rotors
Guys and Gals,
I need some better front rotors for my 2014 Z51 (Still running the crappy originals) I will track the car a couple / few times a year at Sebring, So lots of heat build up.... Does anyone have any good advice for a set? I don't mind spending 5 to 600 for a pair, but trying not to do 500 a rotor. Any ideas? |
in for answers
Originally Posted by jbretthorton
(Post 1599051977)
Guys and Gals,
I need some better front rotors for my 2014 Z51 (Still running the crappy originals) I will track the car a couple / few times a year at Sebring, So lots of heat build up.... Does anyone have any good advice for a set? I don't mind spending 5 to 600 for a pair, but trying not to do 500 a rotor. Any ideas? Fronts from Amazon Part Number: 23242229 Rears from Amazon Part Number: 23322785 Amazon will probably be a lot less. Other than those rotors you are looking at a lot more expense. https://www.essexparts.com/essex-des...ont-c7z51-pair https://www.essexparts.com/essex-des...c7z51base-pair If you are only doing a few track days a year it will be hard to swallow $2600 for rotors that will still wear but not as fast. Replacement cost will be better at approximately $600 for two rotor rings and associated hardware to replace the rings on the hats. You can get a set of four slotted DBA single piece rotors for about $820. https://www.zip-corvette.com/14-19-c...ke-rotors.html Bill |
