Shocks recommendations
1982 Base mod shock recommendations? I'm running 255/70R15 tires if that means anything.
I've been looking at shocks myself for my 72. For my purpose, I will probably go with a simple AC Delco OEM style replacement.
Most vendors sell them as a matched set of 4 for around $160 |
That is what's on it now. was just wondering what other people thought.
I have had AC Delco, Koni Oil, KYB, and currently Bilsteins on my 78 C3 over 40 years and by far, the biggest improvement in ride and handling that was very noticeable are with the Bilsteins..hands down. Bilsteins are quite reasonable in price, come with a lifetime warranty (they used to), and in all the cars that I have used Bilsteins over many years, I have never had one wear out or fail..German quality.
I also use Bilsteins on my 1994 Mustang GT and 2008 Chrysler 300, both applications the Bilsteins transformed the ride and handling. They are simply the best shock/strut you can by at their rpice point..period.... |
Originally Posted by fastimes
(Post 1599053482)
Most vendors sell them as a matched set of 4 for around $160 On my 71 base coupe I've used Delco gas shocks, front and rear. work well, not stupid expensive. However they don't last forever. Good luck. |
Originally Posted by finest kind
(Post 1599059301)
HI,
Bilsteins only cost a bit more than cheap shocks. For a stock-ish car, Bilstein HDs. For a stiffer slung car, Bilstein Sports. If you have an unlimited budget, then QA-1 double-adjustables, and the shocks won't be the only thing you change.
Are you sure about that tire size? 255/60R15 is stock for your car. |
Depends on what your going to do. The Bilsteins are good for racing and autocross. I put KYB on my 79 for street driving and I did do autocross and they performed well enough for me. The biggest help I found was to put a strut brace in as well.
QA1, very good shocks.
Yes, 255/70R15 I bought them by accident but they are working very well!!!
He has a stock GM base fiberglass rear mono spring so he really needs Bilstein "Sports" on the rear, without any hesitation. The "HD"'s are a bit soft for that spring.
Wow. I am amazed that 255/70R15's fit. The biggest on can put on the front of my 68 is 235/60R15....I used to have 245s but they rubbed (barely, but they did).
Here is a size comparison website. That 255/70r15 is quite tall. https://tiresize.com/comparison/
Originally Posted by Stevie1982
(Post 1599063239)
(Post 1599052554)
I too find it hard to believe you can clear 255/70's, especially up front. I'm running 255/60-15's all the way around on my '73 and the left front just touches the frame on full lock turns. Unless your shocks are totally shot, changing to a 225/70 or 255/60 will make more of an improvement in how your car rides than almost any shock you put on it currently. I do like and use Bilsteins on all of my vehicles and have Bilstein Sports on my '73 convertible currently. Good luck and do let us know how it works out... GUSTO |
Originally Posted by Gunfighter13
(Post 1599063203)
AC/DELCO
https://www.rockauto.com/en/moreinfo...041185&jsn=470 https://www.rockauto.com/en/moreinfo...041185&jsn=469 If you are just cruising, these are the best. But: If tracking / sport driving the Bilstein are good. |
(Post 1599052554)
I also run Bilsteins and I think they ride much better than AC/Delco or Monroe. My 75 Vert had HD's with a glass spring on the back when I bought it and it was too bouncy for me. No bounce at all with my Sports and the ride is still good. I would go Hd front and Sport rear with the glass spring for cruising.
Mike |
