FnSquirrel |
03-16-2019 12:55 AM |
Upper steering column bearing install?
Hey all! I bought this C3 (1974) for myself to drive after doing a slight restore. I removed all of the interior to redo the dash harness and to do general dress up. During that process I removed the steering wheel (tilt and telescoping column) and some other parts so that I could remove and replace the lock cylinder. As I was trying to reinstall the tiny clip that holds the upper shaft in place (the clip that looks like a large "U") the inner part of the upper bearing (below the loaded spring) popped up and out of the bearing (the visible side of it looks to have a c-clip on it), so now the upper shaft obviously flops around. How do I re-insert that piece that appears to be in between the bearing balls and the shaft that the upper inner shaft fits inside of? I tried just getting it lined up and hitting it home with a properly sized pvc pipe, with no luck. Do i somehow compress that c-clip?
Any help would be greatly appreciated! Thanks!
