Power windows
Have an 81 corvette both windows stop working have power to one side of circut breaker power to one wire on relay and no power to switches and all are new any suggestions
https://cimg9.ibsrv.net/gimg/www.cor...0af888f95b.png
I'd follow the above instructions just knowing that you don't have the same relay. Here is the actual circuit below... and it'll help you a bit more. You need to see if there is deflection in the amp gauge before you tear something apart. If there is the issue is probably in the gearing or the motors. If you do have deflection in the amp gauge then you need to go to the motor. If you don't then I'd follow the schematic below and figure out the issue. Willcox :thumbs: https://cimg9.ibsrv.net/gimg/www.cor...ffb52f2db1.jpg |
1981 power windows
[QUOTE=Doeman;1599108303]Have an 81 corvette both windows stop working
Gonna try what you suggested thanks somone disconnected theft deterent and power locks don’t work anything to do with windows just wanted to throw this in |
81 power windows
so i only have power to one side of circut breaker and I put a new horn relay in and with ignition off relay is hot there is power on middle wire but hot to touch any suggestions
Originally Posted by Doeman
(Post 1599183503)
Disconnect the wire that is not hot on the circuit breaker and see if you then have power after the wire is removed. sounds like something is shorted after the circuit breaker. Don't get how the ignition relay is hot without power from the circuit breaker..tell us what letter as in the Wilcox diagram you are talking about. Richard |
Power windows
Its number 76 on your schematic power window circuit breaker 30 amp removed it and checked both connections only power to one and like i said with no ignition on the horn relay gets hot no power on pink wire either coming out of fuse box or on switches used a jumper wire from battery to switches windows go down fast but don’t want to go up
(Post 1599184047)
The horn relay warm- usually when there is an issue with the horn. Often the relay is stuck on -thanks to a bad or shorted horn button- the heat is coming from the coil being energized. Just a guess your horn probably doesn't work. Putting direct power on the switches and no up- could mean bad switches - bad motors - bad wires into the door. PLEASE use a fuse in-line when you are doing this...you can either torch wires- parts or the whole car., You need to follow along the diagram and trace back to the source- otherwise throwing un-fused power to things is going to do damage. Richard |
https://cimg7.ibsrv.net/gimg/www.cor...e929b14fc.jpeg
Does anyone know how this comes apart to put in hole in drivers window goes in rear hole for guide cant seem to separate unless goes in another way help
Originally Posted by Richard454
(Post 1599183919)
That does not get separated.
RVZIO |
