LT5 Valves
Do LT5’s ever require any valve adjustments? If so, How is it done?
Originally Posted by glass slipper
(Post 1599140548)
The LT5 has hydraulic lifters, no valve adjustment required.
stockers do fine up way past redline. I've kissed 8k a couple of times and can see where the valves started to get away and kissed pistons fastlane revved to 9k plus with custom build chains that he changed often as a valve adjustment is manually shimming the lifter *engine pull* |
