Did My Motor Blow? Hope Not! Video and Sound. (UPDATE)
2013 Grand Sport, bought new and babied for 26k miles. I changed the oil yesterday (dry sump) like I always do every year at this time. I only put 1000 miles since the last one. Always Mobil1. That's a little background. I have been using the car these two days and noticed when I was parking it today a ticking or whatever sound. I opened the hood to listen to this. At first I thought it might be the compressor but on or of makes no difference (doesn't mean it can't be the clutch) However the sound seems to be coming from all over consistently, each side of the motor, each wheel well and underneath (from bending down and listening). Tell me I'm not screwed, but if it is I have to accept it.
Wouldn't a 'blown' motor throw a code?
Torque tube?
Originally Posted by airmed2
(Post 1599184073)
Pretty loud, possibly a bad/stuck lifter?
If lifter hope it didn't wipeout a cam lobe or 2. |
Originally Posted by Landru
(Post 1599184219)
If lifter hope it didn't wipeout a cam lobe or 2. you may want to remove plug wires one at a time to see if you may be able to isolate it to a particular cylinder.................. use caution when doing this, use tools to remove wires which are insulated so you don't get voltage through you........... |
That don't sound like anything internal inside the engine.
Get under the car and look at the harmonic balancer when it's not running ... Is the front of the balancer chewed up from rubbing up against the steering rack (that sets right in front of it) ? Does the rear of the balancer look like it's been rubbing up against the timing chain cover ? _________________________________ If that's ok ... remove the serpentine belt (the long one .. not the short one that turns the AC compressor) Start it up and let it idle for about 15 seconds without the belt (won't hurt anything) .... Does that noise go away then ? If the noise then goes away, you have a problem with one of these: 1. Water pump 2. Alternator 3. Power Steering Pump 4. Belt Tensioner 5. One of the 2 Idler Pulleys . |
Sounds like your harmonic balancer is rubbing the steering rack.
Tom |
Originally Posted by rkj427
(Post 1599184244)
:iagree: oil pressure reading is:_____________________ does it increase in frequency with rpm increase:__________________
you may want to remove plug wires one at a time to see if you may be able to isolate it to a particular cylinder.................. use caution when doing this, use tools to remove wires which are insulated so you don't get voltage through you........... Just off the cuff, the odds of this being a "blown" motor are somewhere between Slim and none, and I saw Slim headin' outta town at high noon. :eek: To me, a "blown" motor is one that doesn't run because it broke a rod, dropped a valve, etc. The OP mentioned clutch (?) but if it was, the sound would likely change when you push the pedal in. |
Originally Posted by Corvette_Ed
(Post 1599184212)
This. If the motor was blown there'd be several codes thrown.
Originally Posted by Oh Boy
(Post 1599184013)
Have you tried using one of the cheap HF engine stethoscopes to pinpoint where the noise originates?
Originally Posted by subfloor@centurytrans
(Post 1599184355)
Uh...no, not true at all.
Yeah, it sounds more "chirpy" to my ears, a pulley or belt may be the culprit, water pump, idler pulley, etc... so nothing really major. Please let us know what you find.
Just recalled where I heard a similar sound and it was the serp belt on my Caddy. It had reached end-of-life and it was a relatively cheap fix.
Lifter or a loose spark plug. Check and make sure all the plugs are tightened properly. If they are, then I'd be looking at lifters. Sounds like a loose plug to me. I had a 78 Trans Am that a plug came loose in... sounded just like that.
(Post 1599184578)
Then I'll believe when I see it, and after many years and even more blown engines, I still have yet to see it.
With a catastrophic failure (like throwing a rod through the side of the block) the motor simply stops spinning. With something less harsh (like a spun main or rod bearing) it'll get noisy and the oil pressure would just start dropping as the motor got hotter. Even if you kept on running it with a bad bearing and it completely seized, you simply wouldn't be able to turn it over anymore. I had three engines let go on me over the last 18 months with spun bearings because of oiling issues (turns out drag racing doesn't play nice with an LS7 converted to wet sump) and there were no codes thrown. I've even dropped a valve twice while doing 130MPH at the track and had a rod come through the side of the block in both cases and once again, there were no codes. |
(Post 1599184578)
(Post 1599184013)
https://www.youtube.com/watch?v=8Xoud0W4mMs Confirm the plugs are tight and check for exhaust leaks. Pull the belts to rule out the accessories. Remove the valve covers and inspect. Hopefully it's one of those. A loose rocker arm if you're lucky. Now I'll tell you what it sounds like to me: a bad valve lifter roller that's grinding a groove into one of your cam lobes. |
(Post 1599184244)
Originally Posted by TCW
(Post 1599184271)
Tom
Originally Posted by Bruze
(Post 1599184308)
Yes, that's the crucial thing to know. Sounds like a belt chirp or something related to that.
Originally Posted by Chevyrelic
(Post 1599184512)
Originally Posted by Andysherman
(Post 1599184641)
Originally Posted by Garry in AZ
(Post 1599184664)
