new PB 9.1@156
Went to TX2K and aired out the new setup. It's a 5.7L, built 4L60, with twin 76mm set at 22psi. Sprayed a little N2O to help spool. It was pushing some water so we stopped there, but got some data and new ideas to improve on. Even drove home 260 miles afterwards!
60':1.531 1/8:6.01@122.9 1/4:9.15@156.48 https://cimg1.ibsrv.net/gimg/www.cor...afc96133ee.jpg https://cimg3.ibsrv.net/gimg/www.cor...3a5b9b85bd.jpg |
Nice trap speed, 8’s on the way !
Wow good first outting
Cool deal sir!
What heads and head gaskets are you using? Studs or OEM head bolts? |
Hell yea buddy!!!!!!
Thanks guys! Capthuff the heads are Edelbrock/LPE CNC 61969. I believe they have 205cc runners, with ARP studs and regular LS1 MLS gaskets. I was thinking about trying some LS9 gaskets, but not sure how much this motor combo has left to give. It also has a stock crank and Compstar rods rated at like 600hp lol. Might need to move up to an LSX 6 bolt combo that can breathe better.
Grats! That's moving!
Originally Posted by Chris Stewart
(Post 1599190693)
6 bolt heads and a nice strong short block will take care of that issue I've seen some good deals on LSX blocks but here is what I'm doing 5.3 alum block, 6 bolt tabs added like the ERL blocks (block is free) stock ls1 stroke forged crank (stocker is pretty strong though!!) forged wiseco or diamond pistons and decent rods and you should be good to 1500+ more than that, you better think about back halfing the car the stock blocks are really nice and with the right setup, a 6 bolt version should be plenty strong looking for companies that can "add the tabs" to a stock block and do it right! I have new lunati 4.0 forged crank and h beam rods, but with this block I'd like to stay stock stroke comments??? the lsx goes for around 2300 and some of the vendor short blocks are around 6500 with good internals it's still a very expensive build any way you slice it!! |
(Post 1599190693)
Very nice pass!! Congrats!
Thanks again guys! Tempting to slap on some LS9 gaskets and try again. The last pass we learned a better launch method that will pull the wheels. All this time I've used the footbrake as high as it can go, about 3K. By accident I did a dry hop in the lanes, about 2000rpm with nitrous on. It actually pulled the wheels up, and didn't realize it until my son told me afterwards lol. Should be an 8.9 launching like that, assuming it goes straight.
Very nice pass and setup Chris congrats.
What alternator/bracket are you running? |
So bad ass.
Thanks yall, and venom it has a Honda alternator that's mounted in the a/c location with a custom bracket.
Some 625's and LS9 gaskets would do no harm.
Last year when I blew my TFS head apart, I went back to my old A&A WCCH Edelbrocks. My car always did run great with them too. Mine were the 215cc CNC'd ones. |
(Post 1599260721)
I may go with the Honda route like you Which model and year Honda? Are you seeing 13+ volts? Do you think a custom bracket and be made again like yours? |
Originally Posted by stevieturbo
(Post 1599262662)
Originally Posted by venomws7
(Post 1599266224)
Yeah I emailed couple of times about this before and I went with the A/C compressor bracket and JEEP Ranger Alternator like you advised but I'm only seeing 12 - 12.5 volts.
I may go with the Honda route like you Which model and year Honda? Are you seeing 13+ volts? Do you think a custom bracket and be made again like yours? https://cimg9.ibsrv.net/gimg/www.cor...786f84e67.jpeg https://cimg1.ibsrv.net/gimg/www.cor...fb85a9cc2.jpeg |
That's awesome Chris! Especially the drive home!
I know there are some people who push a lot more power through 4 bolt heads, but I kind of gave up on that after replacing head gaskets twice and upgrading the studs. With LSx platform 6 bolt is the way to go, especially with the power your going to be able to make. |
beautiful, what kind of IATs are seeing on the big end?
curious what people in that power range are seeing |
Thanks, it's got a 7 gallon A2W and with only 1 bag of ice, the IAT went from 85-115 degrees. The previous run I forgot to turn on the water pump. The IAT was still only 95-145 and went 9.2@155.
