C7 z06
I just put a set of 2018 Z06 wheels on my 2011 Grand Sport. They look very nice. Question.....will the tire pressure sensors match up with my 2011 Grand Sport? Can it be programed to show the correct air pressure? Thanks....
I'm sure someone will correct me if I'm wrong, but I'm 99% sure the C7 sensors will not work with the C6 receiver. You'll have to have the sensors replaced in each wheel.
Can’t you tell if it sync? Meaning inside does it read any PSI? Or is it all zero PSI
I'm not getting the correct reading yet. I'm getting 37 in 3 wheels and 36 in the other. Manually checked with my gage I've got 31 in all 4 wheels.
I was told it would work but so far it hasn't.
Maybe a stupid question as I don't know but your old ones from your GS don't fit the new wheels?
I'm sure they would but these wheels came with the sensors installed an my sensors in my Grand Sport were original and one was starting to give me trouble. Thought maybe I could get by using these new ones.
Would like to see a picture of your car with those wheels
You should have changed your old ones over to the new wheels because they won't work.
jrose I was starting to have problems with the old ones. These new wheels have been road force balanced and I was told by my service tech at my dealer that they would work.
Originally Posted by doubleD
(Post 1599201856)
Verify with another gauge
5 psi variance between the TMPS and a handheld gauge may not be out of the realm of possibility. I would raise or drop 1 tire by 5 psi or so and see if it registers in the car.
I'll try it thanks
I've done some research this afternoon..... The sensors in the 2011 Grand Sport was 315 mhz. The C7 Z06 has a 433 MHz sensor. So they will not work. I'm going to have to buy new C6 sensors to make this work. Thanks to everyone who tried to help.
sell those C7 sensors over on the C7 for sale forum for $20 more than what you spend on new C6 sensors. they are used to overpaying for everything. ;)
So... $360 in new sensors and you’re in business. What’s the hold up?
(Post 1599204194)
I believe we need pictures of the wheels on the car to verify.
SPSandman if I knew how to send a picture I would be glad too. I'll see what I can do..... I've been on this forum for over 15 years and have not sent a picture.
