Porting service ?
Hi,
please help me with this: I recently bought a superram that I want to port could somebody let me know who can do this ? only runners and plenum, tpi big mouth is already ported but the guy who made this job is not porting more. thanks in advance |
Came from Lingenfelter so it stands to reason that they have the program to port it.
The plenum doesnt need any work unless you hack up the runners & for most 350s its a waste of $. What are you building?
350, 195 afr, 280xfi cam
big mouth base already ported to 195cc all the good dyno number that i saw and read about this combo have the runners and plenum ported , good for 5800-6000 rpm |
I doubt you need to port the runners/plenum, just use a gasket and port match them to the base. The super ram plenum and runners should have no problem supporting a 350ci to 5800-6000 rpm with those heads.
My super pulls to my 6000rpm rev-limiter on my 355ci no prolem. If it was a high-winding 383 you night consider porting but for a 350 you should be good to go with just a little port matching of the ruuner to base. |
I was really impressed with Chad Spier and the thread he did a while back.
Wish he was a forum sponsor and would cut us all "corvette forum buddy" deals. :D That guy knows what he's doing. |
Id have to search for pics but have butchered those pretty good to the point where the entry from plenum to runner was 2x2. Waste on a 350 though and a chit ton of noise/time.
If you want to improve it work on the inside turn a little but dont expect to feel anything;they really arent a restriction (flowed them on bases, by themselves, w/heads etc. |
