Question about passive keyless entry system
I have a problem with the passive keyless entry system on my 94 vette. my fob has a new battery in it and the fob will open the hatch and unlock the passenger door,but it willnot lock or unlock the driver's door and it will not lock or unlockas it should when I walk up to it or walk away. Has anyone experienced this before. all comments are greatly appreciated.
Originally Posted by RedC494
(Post 1599208910)
New problem battery hold a charge now
Additional problem now has comeup has anyone had a issue with the battery not holding a charge when you have a problem with a bad PKE module? Battery is draining down in about 12 to 14 hours. I have had the battery checked and the starter and alternator. all good anyone got any idea's?.
Pull the fuse for the PKE module and you might find out.
Good idea ! I believe it fuse 26 if my memory is any good. Thanks for the response.
