New to me Corvette
Hi all I finally fulfilled a life time dream and purchased a 95 LT4 coupe with 62,000 miles and super clean.
My main question is how often should you change oil using Mobiil One synthetic oil? The previous owner changed every 2,500 miles. My driving will be 85% highway 15% town. Thanks in advance Hawkeye56 |
Welcome
Hi Hawkeye56. First of all, welcome to the a Forum, and congratulations on your new Vette! Just to let you know, the LT4 was only made in 96, and was only available with the manual transmission. Either you have a 96, or your engine is an LT1. Try to post some pictures for us, please. If it is an LT4, the intake will be red.
Regards, John |
Yes you are correct it started as a LT1 with every option available in 95 for a coupe with a six speed. I receipts showing in 99 he had the Chevy garage upgrade to a LT4 and yes it has a red intake. I would post pictures but have no idea how to do it. Thanks Hawkeye56 |
Originally Posted by Hawkeye56
(Post 1599218737)
Originally Posted by JBPC4
(Post 1599218860)
Very cool! Congrats on the purchase. Any idea if the whole engine was swapped over or just all the LT4 bits swapped onto the lt1? It doesn’t matter either way just curious.
400hp 350 torque. He also changed the rear end to a 3:50. |
Welcome! To be safe, I change my oil every 3,500 miles with Mobil 1 10-30w full synthetic and a Mobil 1 or Fram's best filter. I don't put many miles on my weekend / holiday driver, so sometimes once a year.
(Post 1599218504)
Originally Posted by RetroGuy
(Post 1599219686)
Thanks Hawkeye56 |
Congrats and welcome and yes your car seems to be the lucky recipient of the LT4 conversion package that was sold by speed shops like summitt and scoggin Dickey it basically consisted of LT4 cylinder heads with valves and springs, a r LT4 intake manifold, LT4 hot cam 1.6:1 roller rockers, and gaskets. Horsepower was supposed to be around 425 crank
https://cimg7.ibsrv.net/gimg/www.cor...21126fa49.jpeg |
(Post 1599219757)
Not knowing how many miles I will drive on perfect summer days I figured at least once a year. Would it be advisable to go 7,000 miles between changes?
Thanks Hawkeye56 |
Originally Posted by Y-bodluvr
(Post 1599219938)
I don’t change mine in 3500 or 7,000 a happy medium of around 5k with Mobil 1 works for me financially and protection wise
Thank You for your reply on the oil change at 5,000. I'am guessing that could be more than I will drive in a year so that will be my number to shoot for or every spring when I wake it up from a cold Iowa winter. |
Here is about the only pictures I have. The chrome wheels are new as of yesterday.
https://cimg1.ibsrv.net/gimg/www.cor...b75723643.jpeg The chrome wheels are new as of yesterday. Hawkeye56 https://cimg4.ibsrv.net/gimg/www.cor...c99c104da.jpeg |
Welcome to the Forum and congrats on your new '96.
I would follow your Owner's Manual on service items. |
(Post 1599218737)
I would post pictures but have no idea how to do it. Thanks Hawkeye56 Regards, John |
[QUOTE=Y-bodluvr;1599219874]Congrats and welcome and yes your car seems to be the lucky recipient of the LT4 conversion package that was sold by speed shops like summitt and scoggin Dickey it basically consisted of LT4 cylinder heads with valves and springs, a r LT4 intake manifold, LT4 hot cam 1.6:1 roller rockers, and gaskets. Horsepower was supposed to be around 425 crank
https://cimg7.ibsrv.net/gimg/www.cor...21126fa49.jpeg[/QUOTE Why would those parts on a stock LT1 be 425 HP but those parts on a LT4 with higher compression be only 330-350? |
[QUOTE=Eljay;1599221911]
(Post 1599219874)
Originally Posted by WhiteC1
(Post 1599221900)
Very cool, Hawkeye56. That engine sounds like a LOT of fun! I was just hoping someone didn't tell you it was an LT4, without you possibly knowing the difference. That's a beautiful car, for sure!
Regards, John |
(Post 1599220173)
yes that is probably the kit he installed on my car, Very happy with it as it is a real power house.
Thank You for your reply on the oil change at 5,000. I'am guessing that could be more than I will drive in a year so that will be my number to shoot for or every spring when I wake it up from a cold Iowa winter. I would strongly recommend that you change the oil in the fall when you park the car. That way any crap in the oil does not sit in the motor all winter. In the spring all you have to do is fire it up and enjoy the ride. Enjoy your new ride. |
[QUOTE=Y-bodluvr;1599222002]
Originally Posted by Eljay
(Post 1599221911)
The fine print is the 425hp was also with a larger throttle body and injectors, headers, reprogramme pcm and a couple of other things also the Hitcam added some power over the stock LT4 Thanks Hawkeye56 |
Originally Posted by jmeyer58
(Post 1599223598)
Hey Hawkeye.
I would strongly recommend that you change the oil in the fall when you park the car. That way any crap in the oil does not sit in the motor all winter. In the spring all you have to do is fire it up and enjoy the ride. Enjoy your new ride. Thanks Hawkeye56 |
