Battery disconnect switch question
I have recently replaced the battery cables on my '64 with the correct spring load connectors. I have a blade type disconnect switch like the one below that I am wanting to use. My concern is the negative post on these switches taper pretty dramatically and when I place the negative cable on it I don't feel like I am getting a good, tight fit. Not flush on the sides.
https://cimg2.ibsrv.net/gimg/www.cor...6f6b70dc79.jpg If you are using one of these along with the original type battery cable connectors, have you had any issues with losing connection? |
I have the same disconnect and have it on the negative post as well.
No issues at all Phil |
Best on the market ,I use it for years
I use it as well but not with the spring connectors..
Originally Posted by 856666
(Post 1599218914)
Originally Posted by Frankie the Fink
(Post 1599218936)
I don't prefer the spring connectors. If I was overly concerned about judging points I might be, however. I had a problem (near engine compartment fire) with the green knob disconnects and would not go back to those, myself. |
Two things you could.do.
Although its recommended to connect the switch to the negative post you could connect the switch to the thicker positive battery post., .Use a copper plumbing pipe fitting as a sleeve over the switch post to tighten it up. Youll need to thin the gauge thickness of the fitting to fit right. |
dad and I have four of them. they all work flawless
I like the blade disconnect, but I am struggling with the spring connectors possible working loose on the negative stud provided. The switch mounts onto the negative post fine. Thanks for the comments.
(Post 1599218914)
here is the one on my Chevelle with a battery topper. it fits snug on the post
https://cimg4.ibsrv.net/gimg/www.cor...ef0935b5ed.jpg |
I have used the green knob disconnect for years and have never had an issue
Originally Posted by LRGO
(Post 1599219334)
(Post 1599219396)
You've been lucky - I've been through about three of them (not the cheap ones) and each one eventually resulted in a non-start condition..
Ditto. |
Nowhere Man. Thanks for the pic. A picture tells a thousand words. Very helpful.
Originally Posted by Panama 58
(Post 1599219465)
https://cimg0.ibsrv.net/gimg/www.cor...635f20e3c.jpeg |
Hey Keith, is that dust I see on top of your Dad's fender????
:D |
It’s a black car. Your see anything on that after one minute of cleaning.
Yes - spring connectors and no issue at all (use on two cars) both on negative battery terminal.
Phil |
(Post 1599218914)
