Suspension cluncking noise??
I have a 08 z51 with an odd noise coming from the rear of the car. Only happens when I hit even minor bumps. With the car off I can push down on the rear corner and bounce the car to even make the sound. I've jacked the car up and pulled back and fourth on the sway bar and it doesn't seem to be loose or worn. I'm just curious if it could still be the end links or would it be shocks? This is very aggravating. Thanks!
Have you checked the axle nuts?
I just changed the sway bar links on my '05 Z51 and it eliminated all suspension noise. My old links were not falling apart but it was very easy to move them around after I removed them. I replaced them with Moog greasable links that I got from Rockauto. You might try disconnecting one of yours and seeing how easily the studs move around in the sockets.
Originally Posted by cadyshac
(Post 1599227044)
Originally Posted by 919cw313
(Post 1599227034)
I'll give that a try on the sway bar end links and check them. It's very possible it's that, the car does have 90000 miles. That also makes me think it's shocks a s well. |
(Post 1599227034)
My car is '05 and has 51K miles, pretty sure my sway links were original. I didn't mention axle nuts but I also recently changed them, the passenger side was loose. The noise I was getting from the axle nut was a "clicking" when I would release the clutch in 1st or reverse and the new nuts did eliminate that noise. The nuts cost about $6.50 from a local GM dealer.
I'd be inclined to suspect the end links first, axle nuts second, and shocks third.... You are on the right track! Please let us know what you ultimately find.
(Post 1599227239)
I had a similar noise and found it to be the adjusters binding, a squirt of WD was the quick fix.
End links. I replaced all four of mine and noise is gone.
Originally Posted by RichKiss
(Post 1599230127)
Originally Posted by GBennett
(Post 1599227079)
Wouldn't the axle nut make a noise side to side?
(Post 1599227239)
...nut was a "clicking" when I would release the clutch in 1st or reverse and the new nuts did eliminate that noise...
So replaced the end links and still have the noise. I'm thinking ball joints maybe? Anyone ever had that issue.
When you said you pushed down on the fender, it can only mean one thing, shocks. Not :cool:
Sway bar links.
When lowering C7 the stock sway bar links undergo too much stress and wear out. They are not designed to be at alternative ride heights by more than .5”. Adjustable sway bar links are needed. It is Very important to install the sway bar links with 0 preload and they must slide right in with no stress on either joint at ride height. Again, at ride height not with the car jacked up. You will not get the right adjustment with the suspension dissembled or relieved of stress not with pressure relieved bottom control arm.
Originally Posted by 05 Wreck
(Post 1599230233)
I agree, 28k on my 05 and factory end links were shot, no resistance at all.
(Post 1599230233)
Nine out of ten times it is the sway bar end links. While you are in there replace the axle nuts while you are at it. It would be a good idea to check all the nuts and bolts making sure they are tight and nothing else is obvious.
(Post 1599226980)
(Post 1599227065)
I haven't tried the axle nut? I will check that as well.
