Oil Leak from oil pan
I am looking for a reliable place near Lake Mary Florida to replace the gasket on the oil pan on my 2006 Z06. Thanks
I saw Orlando has a few shops. I would ask any local Vette club who they use. It will be $$$
You might ask here in your regional forum.
https://www.corvetteforum.com/forums/southeast-42/ |
I have not used them but hear good things about "Corvette Masters" in Maitland, just a little south of you.
Not a hard job, there are Youtube videos that will help. The dealer wanter $920.00 I did it myself for about $65.00.
Originally Posted by royalcasa
(Post 1599227891)
Originally Posted by cmonkey713
(Post 1599234734)
Thanks for responses
1 Attachment(s)
Originally Posted by windyC6
(Post 1599236165)
What were the major disconnects (if any) required to raise the motor high enough to perform the change ?
I chose to drop the cradle instead of raising the engine as I don't think you can raise it high enough. First time I did it was with a cherry picker supporting the engine. It's harder since the legs are right under the oil pan and it basically trapped the cradle under the car. Second go around I just used ratchet straps around the headers attached to the rafters above the engine. Way easier since there's no cherry picker legs under the car and you wouldn’t need to remove the hood. It was a 2 hr job from changing the oil pan gasket from start to finish the second time I did it. Off the top of my head when I did my oil pan: Jack front of the car up and drain oil Support engine Remove front wheels Remove upper control arms hardware Remove lower shock mount hardware Remove EBCM hardware Remove power steering cooler hardware Support front cradle with jack Disconnect steering shaft Disconnect steering rack lines Remove 4 cradle mount nuts Lower cradle Remove oil pan and replace gasket. Reverse steps for install Attachment 48348457 |
(Post 1599236165)
(Post 1599234734)
My question is: How bad is it leaking? Just curious.
Thanks. |
Originally Posted by Bruze
(Post 1599248735)
That's fine if your time has no value.
you will most likely need to do the front cover as well....just FYI......just had mine done at Powertech in St Pete
1 Attachment(s)
(Post 1599253108)
It's great fun when you are retired and mental therapy too. A day spent with your Corvette is a good day.
I would much rather sit on my porch and drink, and pay my buddy to work on my car. http://i68.tinypic.com/j9mxqh.gif That also helps me from being the richest guy in the graveyard. :eek: Attachment 48341172 |
(Post 1599254113)
I'm burned out from a lifetime of fixing things.
I would much rather sit on my porch and drink, and pay my buddy to work on my car. http://i68.tinypic.com/j9mxqh.gif That also helps me from being the richest guy in the graveyard. :eek: https://i.imgur.com/yPBmDtg.jpg |
Originally Posted by Jimmy W1
(Post 1599252016)
Thanks. |
(Post 1599254694)
Well heck there Bruzey....i'd sit on my front porch more often too if I had a front yard like that !!........:thumbs:
2 Attachment(s)
(Post 1599258370)
Fix me one, I'm coming over. :thumbs:
http://i64.tinypic.com/24pjjmh.gif Attachment 48348427 |
