front window trim,(took 6 hours) what next?
Ok, that was a struggle, now the trim is off, I have rubber all around the window glass, do I use piano wire all around to free up window to lift out? (not sure if this is stock with rubber)
64 coupe. and after clips are changed what do I use to put back in? silcone? or roll of tar from window place. |
Originally Posted by autoalain
(Post 1599228837)
64 coupe. and after clips are changed what do I use to put back in? silcone? or roll of tar from window place. Make sure you get a quality replacement glass! |
Just Cut the rubber with the utility knife make sure you don’t use a metal one you could scratch the glass use one with a plastic handle. Obviously you need a new rubber weatherstrip and the proper adhesive to put it back in. Make sure you buy the American made clips not the cheap Chinese ones. Never use silicone.
Originally Posted by 65 Pro Vette
(Post 1599228897)
