Upgrade advice/Build thread
I'm looking to do some upgrades on my Z. I was originally going to do some driveline upgrades with exhaust.
Looking at: McCLeod or Monster twin disk, slave, remote bleeder poly couplers and bearings for torque tube TSP headers or Kooks. Do the Kooks justify the extra 800 bucks? PFADT trans brace LG tunnel brace Then I got to thinking about the other parts I would like to change and figured if I'm going to pull the back half of the car out to do the clutch and TT. Then I might as well separate the car from the front and rear subframe and do it all at once. My buddy has a twin post lift in his garage. So what I'm looking at motor wise: TSP 225 heads or trickflow 220 TSP torquer V2 cam (or any other recommendations) 3/8 pushrods LS7 Lifters w trays Harlan Sharp rockers Gasket kit ARP headbolt kit. Melling High pressure oil pump Cloyes single roller chain Am I missing anything? Any other recommendations? Thanks KT |
If you are going with a twin disc look at RPS BC-2.
Katech remote bleeder Sac City Corvette transmission mount Melling 10296 I'd go with the C5-R timing chain and "while you're in there," replace the harmonic balancer to ATI 917266 and ARP Bolt. Have fun. All good stuff. Spaggs |
Spaggs,
You like the LUX better than the PFADT trans brace? Any reason why? |
Originally Posted by KT35
(Post 1599231289)
Spaggs,
As for the timing chain I used this..
https://www.corvetteforum.com/forums...-no-equal.html There is a person in the Facebook groups making the Pfadt style mount for 250.00 |
Originally Posted by Smoken1
(Post 1599231900)
Since your block should be drilled and tapped look into this
https://www.briantooleyracing.com/ls...-88958607.html |
Out of those 2 head choices the tfs 220’s for sure, mill to bump compression and run thinner head gaskets, Johnson 2110 lifters, stock rockers with trunnion upgrade, new stock oil pump, powerbond pulley, arp crank bolt, pick the cam that YOU want and that works for your build cause you’ll probably get 30 different suggestions
Most of my mods have to do with sustained HPDE events. I have some budget hp mods, but the aim is to make things last. I went with AMP motor mounts and wanted something similar in the rear. It is polyurethane incased in steel and not outrageous in price.
Spaggs |
Ooops. That's AMT not AMP. I also installed their camber kit and seat rails. It's cool stuff.
Spaggs |
Originally Posted by Spaggs
(Post 1599234685)
Spaggs |
Are the Kooks worth the extra money over the TS headers?
Oil pump
You are going to want a high volume pump, not a high pressure pump.
the high volume pump will compensate for any engine wear in the oil supplied rotating parts group |
Another question.
Which injectors do I need to get. I know I will be maxed out on the stock injectors. Will the FAST 36lb injectors be good or is there something else out there? Monster twin disk, LUX trans mount, TSP headers and mid pipe Torque tub rebuilt kit LG Tunnel brace Have all arrived. Just putting together then final list of parts for the top end. |
https://cimg7.ibsrv.net/gimg/www.cor...ade1f0772.jpeg
https://cimg8.ibsrv.net/gimg/www.cor...2f9bdc164.jpeg https://cimg9.ibsrv.net/gimg/www.cor...fb813d179.jpeg The driveline work is complete! Now I’m Trying to decide if I was to do a H/C/I or a A&A kit. Any recommendations? |
I got the new rims and tires on too! I lowered in on the stock bolts.
https://cimg2.ibsrv.net/gimg/www.cor...493065909b.jpg I decided to to the A&A kit. It was ordered on Friday so now I wait. I am going to change the balancer to the summit balancer. https://www.summitracing.com/parts/s...ions/year/2003 Do need to change anything else? I thought about doing a cam but not sold on that. KT |
https://cimg6.ibsrv.net/gimg/www.cor...3443626a9b.jpg
The A&A kit has arrived. Just waiting on a few more parts before I get started. The question is should a just go ahead a do a cam since I"m going to have everything tore down already? KT |
