85’ vacuum hoses
My 85 in idle will show RPM’s all over the place. It’s not steady. Sometimes the car will stall and die.
my vacuum hoses are messed up. Can that cause the issue and how can I go about fixing it? also, what’s that circle looking thing above the battery. Drum looking thing? |
its the cruise control controller.
there was a guy here a few weeks ago eith vac lines from an 85 in a thread. did u search forum? should be able to find his posts. your vacuum system MUST be up to spec especially on the 85. it doesnt handle compensation as well as 86 and later. repair vac lines do minimum idle procedure report back |
Originally Posted by VikingTrad3r
(Post 1599234536)
https://www.corvetteforum.com/forums...post1585483576
Measure them, or just cut pieces as samples, and go to the part store and get some new lines of the same size and replace them. :cheers: |
I had the same issue when changing my injectors the plastic shattered, and the diagrams help alot, i have an 85 also , now i never had the check valve off of the plenum in the back, i ran it to the vacum tank, my idle is almost solid, and i have cruise,as and heat so sometimes it just works without knowing why
Originally Posted by 85vegasvette
(Post 1599243214)
