1972 Big Block Swap Offical thread (pic heavy)
Figured i would just make 1 thread for all the updates.
Here is a little background - 1972 Corvette Roadster with nonmatching #s 350 and a M20 4 speed. Car was frame off restored in 2008 locally. Have scoured the net and these forums for assistance on this swap - now while this has been done numerous times, the questions I searched for had varying answers. I am humbly posting this hopefully as an all inclusive (for my car) should someone wish to have detailed specifics on this type of swap on this year and model Corvette. I am installing a 454 big block. So far I have ordered the following new parts: -Auto Gear M22Z 4 speed -Stinger Fiberglass L88 hood - Rear wheel bearings (not related to the swap) -New radiator support BBC -New radiator mout and sealing kit BBC -New BBC accessory brackets (alt, power steering) -New BBC power steering pulley -New Centerforce DF clutch Still a TON more to order but I can only spend so much in a week lol. Here are some pics below of before the work and the start of the swap. https://cimg6.ibsrv.net/gimg/www.cor...1d00aeac81.jpghttps://cimg9.ibsrv.net/gimg/www.cor...c6458f793b.jpg |
Now for some pics of parts and work:
https://cimg8.ibsrv.net/gimg/www.cor...3c0e19e30d.jpg https://cimg2.ibsrv.net/gimg/www.cor...92590c58aa.jpg https://cimg5.ibsrv.net/gimg/www.cor...e65910be5d.jpg https://cimg2.ibsrv.net/gimg/www.cor...d2b1224f58.jpg https://cimg0.ibsrv.net/gimg/www.cor...bfdc9940b9.jpg 23x17 radiator https://cimg8.ibsrv.net/gimg/www.cor...db2f9c1dea.jpg Wheel bearings in https://cimg2.ibsrv.net/gimg/www.cor...1cdfbf4ac.jpeg Brand new M22Z |
If you are going to reuse your current alternator you will need a new pulley. Just found out as I was putting power steering on my brother's 68 427 car that the PS and non-PS cars have different alternator pulleys.
Originally Posted by kossuth
(Post 1599234170)
Help me understand ? :) |
Originally Posted by Userj8670
(Post 1599234243)
I had power steering before and will continue to have power steering. My pulleys will be set up for a short water pump using V belts - same as before?
Help me understand ? :) https://cimg0.ibsrv.net/gimg/www.cor...e46dfa59fb.jpg Will |
Originally Posted by rklessdriver
(Post 1599236372)
BBC with a short water pump that have power steering use a different alternator pulley, because the alternator is driven off the power steering pulley not the crankshaft pulley as common on SBC. This places the BBC alternator pulley further forward. The pulley is this one.
https://cimg0.ibsrv.net/gimg/www.cor...e46dfa59fb.jpg Will Anyone know where I can find a new chrome alt pulley? Thanks again! |
A standard double alt pulley running belt jn front groove will work for that setup. I betcha that pulley is not easy to find.
The correct factory style pulley is very easy to find and there as reproductions are currently mfgrd. All the Corvette specialty businesses sell them for $45 or so.
https://willcoxcorvette.com/corvette...r-pulley-66-72 Will |
Trying to reuse your current pulley won’t work. It will put it about 1/2 a groove off. Just went through this with my brothers 68 big block car adding power steering to it where it originally didn’t have it. Picture for reference. You can see the rib and groove on the power steering pump pulley.
https://cimg2.ibsrv.net/gimg/www.cor...77d90659d.jpeg |
https://cimg2.ibsrv.net/gimg/www.cor...9296996215.jpg
Before electric fan went in. https://cimg6.ibsrv.net/gimg/www.cor...0c1b1367ad.jpg After fan and spreader bar. Look at all that room! Or you could go with a March serpentine belt set up. Looks cool, way more reliable in the long run. I went that route and then changed out the fan to electric so I could add a spreader bar in there as room will be at a premium in the front of the motor once you tuck that 454 in there. Pictures of my set up. |
Your 454 belt configuration should look like this:
https://cimg1.ibsrv.net/gimg/www.cor...67fa818c52.jpg For your chrome alternator pulley, you could try spacing out the alternator to line it up with the outer PS pulley. Here is an example of spacing out the alternator, but it still didn't quite line up like the correct pulley. Wrong pulley: https://cimg0.ibsrv.net/gimg/www.cor...f3e0cf1ced.jpg Correct pulley: https://cimg0.ibsrv.net/gimg/www.cor...65d347deb5.jpg |
Thank you all!
Went ahead and ordered the BB pulley. Is there a favorite brand of aftermarket pulleys that will work (non serpentine?) for the crank and water pump? |
(Post 1599243807)
Thank you all!
Went ahead and ordered the BB pulley. Is there a favorite brand of aftermarket pulleys that will work (non serpentine?) for the crank and water pump? https://www.corvettemods.com/C3-Corv...SABEgJP6PD_BwE If you are thinking chrome I have no idea where to find that. Might need to to talk to a local motorcycle shop and see what kinda trouble you would be looking at. |
This pic shows you all the stock type BB pulleys you will need if you want to go that way: They are all available in repro houses. Everything is specific to a BB w/ PS. You need them all, the alt and ps stuff. I'm in the middle of accumulating them myself. The PS pulley is only avail in cast iron and goes for around 120 by itself. The rest of it adds up because you need so many pieces. Maybe $400 for all of it.
https://cimg1.ibsrv.net/gimg/www.cor...67fa818c52.jpg https://cimg9.ibsrv.net/gimg/www.cor...368020f7ad.jpg https://cimg1.ibsrv.net/gimg/www.cor...df1f727c8c.jpg Pics from Paragon |
(Post 1599246004)
https://cimg1.ibsrv.net/gimg/www.cor...67fa818c52.jpg https://cimg9.ibsrv.net/gimg/www.cor...368020f7ad.jpg https://cimg1.ibsrv.net/gimg/www.cor...df1f727c8c.jpg Pics from Paragon I was hoping i could run aftermarket billet pulleys on the crank and water pump and be ok? I would think I should be assuming I make sure they are for a short water pump as the rest of my pulleys and brackets are for short water pump. I did have billet pulleys on my SBC and had no issues - certainly cheaper than OEM:thumbs: |
Would this one work? https://www.ebay.com/itm/BB-Chevy-BB...cAAOSw8PJcVeUI
Just stick with the factory / repro pullies and you won’t have any problems. I did the swap you are going and got everything from Corvette Central. Takes the guess work out of it. You’ll spin the water pump the correct speed and won’t have issues with overheating. Be prepared to “tweak” the lower PS pump bracket to properly align the belts. It will take about 10 attempts. Lol...
Good luck on the build. |
Wow....your flywheel was toast.......good thing you pulled the engine! What are you going to do with all of that cool small block stuff?
Jebby |
Originally Posted by Jebbysan
(Post 1599264322)
Jebby |
Update
Good morning -
Here is an update: block is being cooked and prepped. Need to order a flywheel and water pump today. New hood arrives Friday! https://cimg7.ibsrv.net/gimg/www.cor...17bc45c75f.jpg |
