MSD Street Fire Coil and distributor cap
Hello, I have owned my 1986 Corvette for about 2 years, I replaced my distributor cap with a stock cap but recently I put on MSD Street fire ignition wires. Now I would like to go with a MSD street fire distributor cap and street fire ignition coil. I read older post that if its not the clamp style hold downs you can modify them. But on Summit one customer said be careful if you have a digital dash. It will throw it off. Also does the 86 have a HEI advance curve Kit? I really cant remember looking at it when I pulled off the cap last time. This is my first experience with a Corvette and appreciate this web site it has got me through a lot with learning more about Corvettes. Thank you
Advance is controlled by ECM. No weights or vacuum advance. I didn't see a application, but it doesn't mean it couldn't be.
For a s near stock car the original ignition system is more the enough.. No need for the more expensive aftermarket coils , wires and Ignition control modules..WW
I tried one a while back and found that the attaching clips just will not work with our distributor. I have an 1986 too. I guess you could cut off the clips and put long threaded bolts in their place ... stock is fine.
https://cimg0.ibsrv.net/gimg/www.cor...33bc8b64de.jpg |
I am thinking just to stay stock, I would like to have all MSD Stuff, because I just bought some wire looms and have to re pull all the wires to run them nice and neat. But I can buy something else for the car if it wont make a power difference. Still up in the air though. Thanks for your help! I really appreciate it.
Originally Posted by Cresencio Aragon
(Post 1599241180)
My wife and I had a really nice Chevrolet Pick Up truck (V-6, 5 speed Silverado 1500) and always being someone who likes to tinker I put a MSD ignition and coil in the truck. I soon started replacing distributor caps and rotors every 6 months. My truck had the small cap HEI system on it and it turned out that inside the distributor cap there were highly charged electrical particles that were developing carbon tracks that were "alternate paths to ground" inside the cap. I switched back to the stock coil and it went away. The MSD coil was just a bit too hot for the small HEI distributor cap used on our engine.
Lesson learned: Don't use a high voltage coil if you have a small distributor cap. We also own a 1968 Corvette, a 427 car that has the entire ignition system by MSD and it has been a great system. Each spark sounds like a welder and the car runs smoothly up to 6000 rpm, what more could you ask for? I have one of their earlier model tach drive MSD Billet Distributors and have great success with them. I did not want to hurt my factory Transistorized Ignition Systems so I pulled that system and installed the MSD stuff back in the early 1990's. You should be happy with a MSD system and their coil as they do improve your emissions and sure make a hot spark (and a lot of them each time under 3000 rpm). I like the ability to crank my timing back 20 degrees while cranking so my starter doesn't have to work as hard. They also have a decent staff to answer questions and they seem to stand by their products. Good Luck |
(Post 1599234984)
Best of luck |
