Use HP Tuners to disable DIC messages
Can it be used to disable messages such as "check gas cap" or "service tire pressure sensors". I have some DIC and check engine codes that I want the car to ignore forever on my race car. Assume HP can do it?
Very possible as it can clear and stop reporting numerous codes.
I believe that you can turn them on and off in the tune by checking or unchecking the enable box.
https://cimg2.ibsrv.net/gimg/www.cor...93f420f337.png |
Nope
Tech 2?
Originally Posted by phils C5 vette
(Post 1599295391)
Nope
Depends what you want to do. You can disable engine/transmission codes, but that is it. Anything controlled by the BCM, SRS, etc cannot be toyed with with HPTuners (or anything else that I know of).
the service tire pressure sensor message is odd because this is the first year receiving it. none of these are causing issues, just annoying to see
Cant do gas cap or TPMS codes.
Could I disable codes P1133 and P1153 with HP Tuners?
I can check when I get home but yeah, should be able to. Not saying you should, though.
Originally Posted by 88redconvert
(Post 1599331356)
https://cimg1.ibsrv.net/gimg/www.cor...fc9b89adbb.jpg |
