2 Attachment(s)
[QUOTE=ttx350z;1599246029]Heres the 315 on 10.5
Attachment 48348458 Attachment 48348459[/QUOT] Well that looks like it will clear the fender lip. At last weekends AutoX another Z06 had the 315 on an 18x11 and he was rubbing ..... even after telling me he sanded the fender lip down after previous event. What offset is that? :cheers: DH |
Originally Posted by Dirty Howie
(Post 1599246995)
What offset is that? :cheers: DH Edit: that pic is with -2.3 camber |
Originally Posted by ttx350z
(Post 1599246462)
The RE71 were pretty new, like 90% tread left at the least the RE11’s were probably in the wear (definitely past the wear bars after lighting them up). Stock C6 suspension. I was used to have nothing but understeer on entry/midcorner with RE11 on the F/R so it was a very sudden change.
This was the before measurements when I took it in for new alignment after installing coilovers this winter, so they maybe a little bit skewed. Front camber was -1.2, toe -0.15, rear camber 1.3, toe -0.10. Front pressure 38 hot/rears i think around 34? |
Originally Posted by PRE-Z06
(Post 1599247660)
Sounds like the 71s were fresh and the 11s were possibly heat cycled out? Saw you’ve added a lot of power and aero in your profile pic so was curious as to what all mods you had done, if you had fresh 11s in the rear it might have been more balanced I’m thinking. It’d be like putting R compounds up front and street tires in the rear, that would be a very tail happy combo and one I wouldn’t recommend.
Mods is just cam, headers, fixed heads, msd, halltech, nw102. Aero mods were ZR1 splitter and side skirts. |
https://cimg7.ibsrv.net/gimg/www.cor...cbd0c67217.png
Here’s yesterday’s results where he placed 4th in PAX out of 157 with the discontinued RE11s on the rear. It still has stock shocks, sway bar and no harnesses. |
(Post 1599314134)
Originally Posted by '12GS
(Post 1599314967)
Stop showing off my slow 9th place finish on here Chris! I had a fast raw time atleast ....
I'm thinking about going with the bfg rivals. 315 30 18 and 345 30 18. Should be rather interesting to see how they handle.
Originally Posted by Mark Leger
(Post 1599315573)
Just finished up my first weekend with brand new still shiny 315 Rival S 1.5 on 18x10.5" front and (well worn used) 335 Rival S on 18x12" on the rear. On Viking coilvers 550 front/700 rear. Event is ran on a concrete pad that's used as a truck stop.
I have very limited experience with the Rival S on the front (275 on a 10.5" wheel) for like 8 runs in mid 30ºF weather. I'll be referencing OUSC competitor Brandon Williams R35 GTR (335 Rival S squared/700+AWHP) quite a bit since he's got competitive experience and fleming23 should know who he is since they've competed in the same event before. So Day 1, it was freezing. It was cloudy and snowing during registration with some moisture/puddles on the ground. Temps where in the 30's until about 1 pm. Of course I got shafted and was in the first run group. First heat was pretty much a lost cause as nobody could get their tires warm. Guys with RE71R's in second run group were only getting 60ºF tires temps after their hot laps. There was no grip at all. So not much to report on. The co-driven GTR was 1/2 after the first heat. After lunch break, it warmed up into the 40's. Grip improved a little bit but there was still no grip for turn in. RE71's were just getting to 80ºF for the second run group. I ended up like 5th raw/pax time. Behind a shifter kart that set FTD, the GTR with both driver, 2 Miatas with RE71R's. Due to the weather and only 16 cars showing up, we finished early so we reconfigured the course to start another "event" it was about 45º at that point and a little overcast. I was able to set the second fastest time behind Brandon's GTR. Day 2, it was 35ºF at the start of the first run, but sunny and no snow. Of course I was in the first run group once again. The main competitors on 71R's and the co-driven GTR was in group 2. The slightly warmer conditions made a huge difference. Turn in didn't just understeer into oblivion at 20mph like the previous day. I had the fastest time posted for run group 1, up on the GTR driven by the codriver .1 sec. I was in 4th at the lunch break, 1.6 seconds off the GTR with Brandon driving in group 2 with the same 2 RE71R shodded miatas ahead of me. Heat 2, warmed up and I was finally able to get a feel of what the car could do. Front end felt great, tires felt stiff and did not feel any sidewall flex/wallowing even mounted on the 10.5" wheels. Visual inspection after the weekend didn't show any signs of the sidewall rolling over and rubbing the ground. I didn't feel like I had any issues with precision as I was able to place the car where I wanted. I came into the weekend expecting it to have oversteer, but I'm happy to report that there was no snap oversteer on turn in or midcorner. Car was very neutral even around high speed (60 mph) sweepers, pulled 1.28G's according to the HUD and would scrape the airdam. Power delivery on exits were great and uneventful in second gear, wheelspin was easily managed even though the tires are at the end of their life. I'll probably do one more weekend with those rears before I get the new set mounted. At the end of the day, I finished 2nd in raw and PAX only behind the GTR with Brandon behind the wheel. I closed to gap considerably to finish .2 secs behind in raw time. I know it doesn't count, but I took off another .4 secs off my time during buck runs at the end of the day. So the cars potential is there, I just have to get up to speed quicker myself. Times are based off of memory and it's been a long weekend. I'll post the times when their available. On another note, the 315 on 10.5" +36mm wheels had ZERO rubbing at all. No rub while staging, hairpins, fully compression sweepers, nada, zilch. I know it's something people will deal with if they rub, but this is still sort of a daily car to me. |
(Post 1599350163)
I have very limited experience with the Rival S on the front (275 on a 10.5" wheel) for like 8 runs in mid 30ºF weather. I'll be referencing OUSC competitor Brandon Williams R35 GTR (335 Rival S squared/700+AWHP) quite a bit since he's got competitive experience and fleming23 should know who he is since they've competed in the same event before. So Day 1, it was freezing. It was cloudy and snowing during registration with some moisture/puddles on the ground. Temps where in the 30's until about 1 pm. Of course I got shafted and was in the first run group. First heat was pretty much a lost cause as nobody could get their tires warm. Guys with RE71R's in second run group were only getting 60ºF tires temps after their hot laps. There was no grip at all. So not much to report on. The co-driven GTR was 1/2 after the first heat. After lunch break, it warmed up into the 40's. Grip improved a little bit but there was still no grip for turn in. RE71's were just getting to 80ºF for the second run group. I ended up like 5th raw/pax time. Behind a shifter kart that set FTD, the GTR with both driver, 2 Miatas with RE71R's. Due to the weather and only 16 cars showing up, we finished early so we reconfigured the course to start another "event" it was about 45º at that point and a little overcast. I was able to set the second fastest time behind Brandon's GTR. Day 2, it was 35ºF at the start of the first run, but sunny and no snow. Of course I was in the first run group once again. The main competitors on 71R's and the co-driven GTR was in group 2. The slightly warmer conditions made a huge difference. Turn in didn't just understeer into oblivion at 20mph like the previous day. I had the fastest time posted for run group 1, up on the GTR driven by the codriver .1 sec. I was in 4th at the lunch break, 1.6 seconds off the GTR with Brandon driving in group 2 with the same 2 RE71R shodded miatas ahead of me. Heat 2, warmed up and I was finally able to get a feel of what the car could do. Front end felt great, tires felt stiff and did not feel any sidewall flex/wallowing even mounted on the 10.5" wheels. Visual inspection after the weekend didn't show any signs of the sidewall rolling over and rubbing the ground. I didn't feel like I had any issues with precision as I was able to place the car where I wanted. I came into the weekend expecting it to have oversteer, but I'm happy to report that there was no snap oversteer on turn in or midcorner. Car was very neutral even around high speed (60 mph) sweepers, pulled 1.28G's according to the HUD and would scrape the airdam. Power delivery on exits were great and uneventful in second gear, wheelspin was easily managed even though the tires are at the end of their life. I'll probably do one more weekend with those rears before I get the new set mounted. At the end of the day, I finished 2nd in raw and PAX only behind the GTR with Brandon behind the wheel. I closed to gap considerably to finish .2 secs behind in raw time. I know it doesn't count, but I took off another .4 secs off my time during buck runs at the end of the day. So the cars potential is there, I just have to get up to speed quicker myself. Times are based off of memory and it's been a long weekend. I'll post the times when their available. On another note, the 315 on 10.5" +36mm wheels had ZERO rubbing at all. No rub while staging, hairpins, fully compression sweepers, nada, zilch. I know it's something people will deal with if they rub, but this is still sort of a daily car to me. Do you think there would still be no outside fender rubbing with stock suspension vs your coil overs. :cheers: DH |
I don't think it'll rub the fender with stock suspension. Now that the shoulders are worn, there'll be even more clearance.
I'm seeing recommendations in forums for re71r 275-35-18/305-30-19 with a slight edge to the rivals 275-35-18/335-30-18. Stock wheels in AS. Any reason not to use the re71r 285-30-18 up front? I assume they would be close in performance with slight edge to the 285. And if South Florida heat would favor re71r or rivals?
Originally Posted by Al.B
(Post 1599360528)
I have not tried the 285s up front because I think they are too short, but it’s possible they will work OK. |
Originally Posted by cpt11gs
(Post 1599362079)
I’ve tried both the Rival S and RE71r in the sizes you list. I do prefer the RE71r for better feel and steering response. But high heat is better for the Rival S. They need some heat in them to work well, and the RE71r works better cold, but can get a bit greasy when hot. So you may like the Rival S better most of the year.
I have not tried the 285s up front because I think they are too short, but it’s possible they will work OK. The first thing I would do is evaluate what temperatures you expect to be running under. If its typically 60 deg and cooler, I would go RE71, as getting heat into the Rivals is tough. If its warmer, I would go to question 2, tire sizing. I run Rivals 315 square, and in the first few events of the year I struggle to get any heat into them in the small courses we run. I am thinking of getting a set of Re71s in 285 square just to help them warm up faster and also get a co-driver to help warm tires. At the end of the day, these tires are really good, and people can win on either one. |
Originally Posted by Rexracer77
(Post 1599364441)
To support this statement, I have been working with a guy that won a national championship in a C5. His experience supports this, the RE71 are faster from the first run, but as temperatures build, he was noticeably faster with the Rivals. He runs Rivals for this reason, and because he can get contingency sponsorship to get free tires.
(Post 1599364533)
I assume you have to be running wider fronts to go 315. Vs the stock 9.5s. also wonder if running rival 275/315 would improve balance, less understeer, help rotation.
(Post 1599365049)
Im running a C4 with Forgstar F14s, 11" wide square. Running a 275 front would be more understeer then a 315 front. But maybe your not comparing the 275 to the 315?
Not new to autocross but will be new to the Vette. Hense some of the newbie questions. |
(Post 1599360528)
(Post 1599364441)
