LS7 crate engine with E-force supercharger
Up for sale is a GM LS7 crate engine that was used by Edelbrock for development & testing on their E-Force Supercharger system for the 2006-2013 Corvette Z06. It comes topped with their Eaton Gen VI E-Force TVS 2300 supercharger rotating assembly with a four lobe design with 160 degrees of twist for maximum flow, minimum temperature rise and quiet operation for excellent drivability. Edelbrock has designed their superchargers with an integrated bypass valve to help eliminate parasitic loss under light throttle, improving mileage potential. The unique and efficient inlet configuration results in a shorter, less restrictive intake path for improved air flow, without the need for a jack-shaft. Keeping the air cool is a high capacity air to water intercooler and low temp heat exchanger. This supercharger system is emissions legal and provides the best combination for your daily driver.
This engine does have forged rods and pistons in it. We have one and only one of these for sale. See it here: https://sdparts.com/rt-4577-sdpc-clearance.html or the direct link here: https://sdparts.com/i-24134222-ls7-c...nt-engine.html $13,999 |
