2007 Twin Turbo Z06
https://cimg1.ibsrv.net/gimg/www.cor...8d4786f6d.jpeg
https://cimg6.ibsrv.net/gimg/www.cor...fa278722c.jpeg https://cimg9.ibsrv.net/gimg/www.cor...e563d0bac.jpeg https://cimg2.ibsrv.net/gimg/www.cor...a5100c4412.jpg https://cimg0.ibsrv.net/gimg/www.cor...a2e2ef8c17.jpg https://cimg5.ibsrv.net/gimg/www.cor...a78cc54cbe.jpg https://cimg7.ibsrv.net/gimg/www.cor...85613a1b4b.jpg https://cimg3.ibsrv.net/gimg/www.cor...c49f30b28f.jpg https://cimg8.ibsrv.net/gimg/www.cor...673445ba7c.jpg 2007 Chevy Corvette Z06 (45K O.B.O.) Title in hand No trades Miles 36000 2000-3000 miles on motor build and setup 650-1000 Horsepower with 5 different boost settings E-85 APS Twin Turbo kit GT 3582R/44MM Wastegates/Blow-off valves Motor LS7 427 Stock Block, Stock Crank, Stock Rods Wiseco Pistons with heavy duty wrist pins New Plugs, Spark plug wires, coils High output Alt. New Starter Ported intake and throttle body Heads Ported and polish Valves cut Cam motion Turbo cam New rockers and pushrods All ARP hardware PAC double valve springs Fuel System Fore Triple Pump 3- 450 pumps Fuel rails ID 1700X injectors Controller and filters Drivetrain Built 6060 trans (RPM Level V equivalent) MGW shifter Mantic triple disc clutch C5 axles 15’ rear conversion with spindles and brakes LG Coilovers Misc. Hinson motor and trans. mounts Dewitt’s Radiator D3 Twin fans and shroud 160 Thermostat GFB Boost controller Dashlogic controller with wideband WOT Box HP tuners Line Lock V1 radar detector hardwired Fan control switch Tow hook LED interior lights and tag lights Z06 Floor mats Car cover Wheels Weld RTS 17x11 with 325-45-17 M&H Rear Weld RTS 18x7 with 245-40-18 Michelin 4s front Weld RTS Beadlocks 15x10 with 275-60-15 Mickey pros Rear Weld Alumastars 17x4.5 with M&H front runners front Billet lug nuts Exterior Roof wrapped gloss black Black Headlights Blacked out side markers Blacked out tail lights Ceramic Coating HID Fog Lights https://cimg6.ibsrv.net/gimg/www.cor...64c43fcc4e.jpg https://cimg4.ibsrv.net/gimg/www.cor...fa364ce67b.jpg https://cimg4.ibsrv.net/gimg/www.cor...1e87d014da.jpg |
Are c5 axels suppose to be stronger than the c6s?
[QUOTE=Faster5;1599264593]Are c5 axels suppose to be stronger than the c6s?[/QUOTE
Yes sir, they are. |
Wow... just WOW.... GLWS
Under bonnet shots ?
Originally Posted by 0H8Z06
(Post 1599265598)
Originally Posted by Mike'sZ06
(Post 1599265686)
Can you add interior pictures to that also?
Originally Posted by Crazy Boost
(Post 1599274812)
Also wanted to add that the car recently had a compression check, leak down test, and a smoke test. The test all check out good and were done by Jordan Performance and Racing.
Very nice build!
Just wondering, do you have a 93 octane tune? |
Originally Posted by MRSUPRA
(Post 1599291669)
Very nice build!
Awesome car. Looks very tasteful inside and out. Is there a reason you didn't do the stock rods while you were in the block changing the pistons? Just curious. Car looks great!
Originally Posted by Josh M
(Post 1599293392)
Awesome car, good luck with the sale
Originally Posted by 449er
(Post 1599294242)
Originally Posted by BRING IT
(Post 1599294210)
Thanks! The stock rods are titanium and there really hasn't been that many issues of people snapping rods. The weak link in the motor is the Pistons and then the next weak link would be the cylinder walls. Of course everybody has a different opinion. Also I wasn't trying to set any records just have a nice 800-900 horsepower car. The car is solid and rolls out!!
(Post 1599295263)
Thank you for the explanation, that makes sense. Car looks great. I love understated and clean looking cars.
I got the car cleaned up this past weekend so I uploaded a couple of pictures. One of them shows actual mileage. Lets make a deal! :cheers:
Intrested in your car got some more questions
(Post 1599260915)
