C7Z Dyno thread
Coming from the cobra forums there were a few threads for dyno numbers. I searched here and didn't see one. I believe it helps plan future mods and see what works for the cars.
Figured a simple list of what is done to the car and what type of dyno as well as a8 vs m7. |
I am looking for stock M7 Z06 dyno’s and with bolt on mods. Hope people post up on this :thumbs:
DYNOJET - 88 deg. F. - 44% Humitity - SAE 1.03 CF - Dens Alt: 2650
'17 M7 - Drop-in Filter, Borla X, Ported TB 1st: 579 / 594 AF:14.63 2nd: 577 / 594 AF:14.45 3rd: 580 / 588 AF:15.00 Installed Halltech Intake to replace the drop-in filter. I can post details later. |
2019 Z06/Z07 A8
Dynojet AFE Intake NW 103 TB Ported Blower 18% lower ARH 2" long tubes Tuned 93/100 octane via dual map toggle switch Trans and engine tuned 702rwhp / 736rwtq |
i have the flowing on my 15 M7 Z
halltech 18 % pulley 1 7/8 headers corsa extreme meth and E85 cooling mods tune i made 696 692 on a mustang dyno with 93 still in the tank. it is nasty fast and makes my stock gen v viper feel slow |
2015 M7
AFE intake Mamo PTB BTR stage 2 cam CNC heads 15% lower kooks 2” headers kooks catted xpipe corsa xtreme DSX Low side fuel kit DSX flex fuel kit weapon x HX 694 on pump 93 729 on E40 (ran out of high side on conservative tune) |
2300 w/ 80mm upper
23% power pulley 103mm TB 5” Custom CAI Heads/cam ARH 1 7/8s meth E50 low side fuel pump 860rwhp |
2019 C7 Z07 M7
Halltech CFV Tony Mamo Ported TB NorCal Cat Delete Akrapovic Evolution 2.175” Upper Alky Meth Dual Nozzle DSX Flex Fuel Cordes Performance Heat Exchanger Cordes Performance Expansion Tank 91/E50 DynoJet 675 RWHP / 671 RWTQ |
Originally Posted by K2XSNOW
(Post 1599322747)
https://cimg7.ibsrv.net/gimg/www.cor...953c53c8c.jpeg
i have cats. hi flo cats gm performance intake pulley, ported s/c and a tune kooks 1 7/8” headers that run was on e47 here is my 93 pull |
Originally Posted by howdigethere
(Post 1599332893)
gm performance intake kooks 17/8” headers that run was on e47 here is my 93 pull Thanks for sharing. Car is bad ass! |
2016 Z
CAI 103 TB Ported blower 2.3 upper pulley 15% lower pully cam/lifters etc. 1-7/8" headers catless x-pipe 720/725 |
2016 M7
aFe Momentum intake w/ dry filter Tony Mamo ported TB ARH 1 7/8" long tubes/catless Xpipe Corsa Xtreme axleback Fasterproms expansion tank 647 RWHP / 657 RWTQ on a Dynamax, 55-60 degree humid day |
2016 M7
Halltech Stinger Borla X-pipe Dynojet 585whp |
Originally Posted by HNK
(Post 1599332416)
The AF is for air/fuel ratio? If yes, isn’t it too lean even for DI??
2-2.5K RPM - ~14+ 4K RPM - 12.4 5K RPM - 12 6K RPM - 11.9 |
2016 Z07 A8
Weapon X build & tune Mustang dyno AFE intake (high flow filter) Norcal cat delete pipes Borla mid pipe (stock cat back mufflers) 18% lower pulley/balancer (Innovators west) Mamo ported 95 mm TB Weapon X ported stock blower and snout Fasterproms ram air Fasterproms thermal insulators Fasterproms Aux intercooler tank Cordes intercooler heat exchanger 160 degree thermostat GM dual fuel kit MTI low side fuel pump kit Alky Control single nozzle (15 GPH) meth kit DSC shock controller Cam & valvetrain stock Heads & block stock 14 PSI boost 704 RWHP--782 RWTQ (SAE) on 93 pump & meth inj. 742 RWHP--803 RWTQ (SAE) on 93 pump, meth inj. & 50% E-85 |
Originally Posted by Ludicrous_Speed
(Post 1599334447)
2016 M7
aFe Momentum intake w/ dry filter Tony Mamo ported TB ARH 1 7/8" long tubes/catless Xpipe Corsa Xtreme axleback Fasterproms expansion tank 647 RWHP / 657 RWTQ on a Dynamax, 55-60 degree humid day Still just 93 octane? |
Need base numbers and post mod numbers to get best value. End results alone will have some people upset if theyre chasing a number on paper or at track.
