Accessory wiring and suggestions for engine compartment buss bar/power distribution
Hey all.
I am going to be running both an electric cooling fan as well as electric headlight motors which will all obviously need power. I have read lots of suggestions of running this directly from the alternator (with the obvious fuses/relays) and so it would seem that rather than run multiple leads from the alternator that a buss bar or power distribution block would be a great idea so I can run a single additional lead to it from the alternator and distribute power from there. I must assume that others have done this. Can you make a suggestion of a brand/model to use for this? Most of the products that I have seen state a 15a per circuit max which will not be enough for some cooling fans (I think). Anyway, I am planning on running something like this: Alternator > PDU >>>>Aftermarket Fuse/Relay box>>>>>>>>Headlights/Cooling Fans Something like this for PDU https://images-na.ssl-images-amazon....L._SL1230_.jpg and something like this for the relays/fuses https://images-na.ssl-images-amazon....L._SL1500_.jpg Any suggestions would be welcome. |
https://cimg8.ibsrv.net/gimg/www.cor...53bbc89327.jpg
Painless sells an auxillary seven circuit fuse box, that needs no assembly and just a power terminal from the battery. I mounted mine on the passenger side firewall. As far as the fans, the relays run off've the auxillary fuse box but the power to the relays comes from the battery. The two post terminal is pictured above and I ran a heavy 16 gauge wire, straight from the battery to one side and then other side, went to the aux fuse block (or box). Works really well! The cover even comes with a label underneath, with blank spaces to write what wire or circuit went to what. Document this too on a piece of 8x11 and put it in your FSM, you'll want to know this later. https://www.painlessperformance.com/wc/70107 |
Fan Relay detail (mounted on driver's side). Driven by the aux fuse box to turn on, but powered from the battery to the fans.
https://cimg1.ibsrv.net/gimg/www.cor...997e9031d6.jpg |
Because firewall space is really sparse in these cars, I carefully mapped out and planned where these devices would be. Also, this makes it easier to manage the wiring, along the back of the engine compartment. When you're doing the crimps, I highly recommend using the 3M electrical crimps, a Matco Wire Stripper and a Matco heavy duty crimper.
https://cimg2.ibsrv.net/gimg/www.cor...e3a6f930dd.jpg |
Here's what I would do- and why....
The battery is like a bank account- the alternator is the income. You want big payments to come out of the bank account. The battery does more than start your car- it stabilizes the voltage surges and filters the AC ripple left unfiltered by the alternator. PLUS when the fans kick on- it's dang close to a dead short to get the blades spinning. That's usually when the car is at idle and the alternator is not putting out anywhere near it's rated power. The battery solves that problem as it has several hundred amp available. I'd also recommend a PWM to power the fans- it's a lot lot nicer to the electrical system- as it soft starts the fans- sort of like a clutch dump at 3000RPM versus a rolling start. I'd run a nice size wire -6 GU from the starter to the alternator- and another wire upfront near the source that will use the power, For the big stuff- I like nice terminals with one of these types of fuses-Marine Rated Fuses https://www.bluesea.com/products/cat..._Battery_Fuses https://cimg4.ibsrv.net/gimg/www.cor...69ffdd86d8.png With that fusebox and 6 relays- you can configure a lot. Can use the relays for the headlights- have switched ignition sources and hot at all times. Lots of options. I've shown the starter as a terminal block so to speak- https://cimg3.ibsrv.net/gimg/www.cor...66083e4683.png |
I have a battery disconnect on the bulkhead between the seats. I takemy main power for my headlight relays and fan relays off the battery wire at the starter. I wired in the switched power for the fan relay off my wiper power. Tthe new headlights harness plug directly into the old headlight harness for thd relay trip. And both main power lines go through a self resetting breaker mounted to the inner fender. The system works great and its wrapped in with original harness so it blends in
For my cabin accessories like gauges, MSD , radio, antenna, and such I added a seperate fuse panel that lights up when a fuse blows. For the subwoofer and amp, they have their own fused wire directly from the battery . Illl post pics later but the idea was to limit long runs of wire where possible |
I used a distrubtuion block from a caprice that is looking full and have been thinking about replacing it with a block from a 88-98 chevy truck.
https://cimg0.ibsrv.net/gimg/www.cor...c714554251.jpg Then a fuse center like others have listed for key on power not battery power. Mounting location has become the issue. |
My second fuse panel has a relay off the original fuse blocks ACC plug to make it key on only
Originally Posted by F22
(Post 1599276382)
Originally Posted by Richard454
(Post 1599276717)
The battery is like a bank account- the alternator is the income. You want big payments to come out of the bank account. The battery does more than start your car- it stabilizes the voltage surges and filters the AC ripple left unfiltered by the alternator. PLUS when the fans kick on- it's dang close to a dead short to get the blades spinning. That's usually when the car is at idle and the alternator is not putting out anywhere near it's rated power. The battery solves that problem as it has several hundred amp available. I'd also recommend a PWM to power the fans- it's a lot lot nicer to the electrical system- as it soft starts the fans- sort of like a clutch dump at 3000RPM versus a rolling start. I'd run a nice size wire -6 GU from the starter to the alternator- and another wire upfront near the source that will use the power, For the big stuff- I like nice terminals with one of these types of fuses-Marine Rated Fuses https://www.bluesea.com/products/cat..._Battery_Fuses https://cimg4.ibsrv.net/gimg/www.cor...69ffdd86d8.png With that fusebox and 6 relays- you can configure a lot. Can use the relays for the headlights- have switched ignition sources and hot at all times. Lots of options. I've shown the starter as a terminal block so to speak- https://cimg3.ibsrv.net/gimg/www.cor...66083e4683.png Thank you for taking the time to respond to this, Richard. I was hoping you would chime in as I know this is your wheelhouse. Your picture reminded me that I totally forgot to mention that will also be running halogen headlights and a MSD ignition system which is why I chose to go with at least 6 relays in the box. Thank you again for the PWM suggestion. I really like the idea of this and did not even know it was a thing. I assume you are talking about the Derale model or are there others out there? I would appreciate suggestions from anyone who uses a PWM on which make/model to get. I do have a question regarding the wiring (actually, several questions) but the first one that comes to mind is that you suggest that I draw power from the battery (which makes perfect sense). Would I then not way to run directly from the starter/battery cable to the PDU/fuse hold thingie that you are showing here? BTW What and where can I get that? What amperage fuses should I be looking to get to go on it? I am a little in the dark as to how to determine what the proper fuse rating should be for any given circuit. Is it simply the combined amp rating of everything drawing off of that circuit? I am certain that wire gauge must also play a part in that? Finally, you mention having always hot and switched power through the supplemental fuse/relay box. How is that done? Always hot would obviously come directly from the battery/starter cable source...unsure about the rest.
(Post 1599276840)
I have a battery disconnect on the bulkhead between the seats. I take my main power for my headlight relays and fan relays off the battery wire at the starter. I wired in the switched power for the fan relay off my wiper power. Tthe new headlights harness plug directly into the old headlight harness for thd relay trip. And both main power lines go through a self resetting breaker mounted to the inner fender. The system works great and its wrapped in with original harness so it blends in
Originally Posted by Kacyc3
(Post 1599276863)
(Post 1599276927)
I'll try and get those posted tomorrow night. I had a spare relay from another wiring kit and they are simple to wire in. I still have everything apart so It wont be a problem
Originally Posted by PainfullySlow
(Post 1599277199)
Thank you for taking the time to respond to this, Richard. I was hoping you would chime in as I know this is your wheelhouse. Your picture reminded me that I totally forgot to mention that will also be running halogen headlights and a MSD ignition system which is why I chose to go with at least 6 relays in the box. Thank you again for the PWM suggestion. I really like the idea of this and did not even know it was a thing. I assume you are talking about the Derale model or are there others out there? I would appreciate suggestions from anyone who uses a PWM on which make/model to get. I do have a question regarding the wiring (actually, several questions) but the first one that comes to mind is that you suggest that I draw power from the battery (which makes perfect sense). Would I then not way to run directly from the starter/battery cable to the PDU/fuse hold thingie that you are showing here? BTW What and where can I get that? What amperage fuses should I be looking to get to go on it? I am a little in the dark as to how to determine what the proper fuse rating should be for any given circuit. Is it simply the combined amp rating of everything drawing off of that circuit? I am certain that wire gauge must also play a part in that? Finally, you mention having always hot and switched power through the supplemental fuse/relay box. How is that done? Always hot would obviously come directly from the battery/starter cable source...unsure about the rest. I'm running the Derale piece- seems they have gotten their act together as far as the temp sensor - as the earlier ones were problematic. Summit sells it- so if I have a problem- they are easy to deal with. It really depends how much mods you want to do to the wiring- just using the starter terminal is the easiest - cost effect and really doing more you are at the point of diminishing returns. Just run a 1/0 GU wire from the battery to the starter and you'll be good to go. The terminals- search "Marine Rated Battery Fuse" the marine stuff seem to have much better quality than the car stuff out there actually Amazon has got some good deals West Marine- https://www.westmarine.com/buy/blue-...09_273_007_517 The 'battery terminal type fuses'- a 75A for the fans and a 50A for the fusebox should be fine. As far as the fusebox outs- 20A for headlight motors- for the headlights you can use a circuit breaker (auto reset type) that fits in a fuse slot- 20A For the MSD - I'm thinking 10A- but check the owners manual. The relays- You can have the battery power hot at all times go to a relay- and have the relay turned on by a ignition wire. see below I really like using the "LED" blade fuse- light up when they are blown- WELL worth the few extra bucks!!!! https://cimg7.ibsrv.net/gimg/www.cor...2ce6efd62a.png As far as switched sources- here's how it works at the ignition switch- https://cimg9.ibsrv.net/gimg/www.cor...8808d9db7e.png Here's what's going on at the harness on the firewall- since you are not using the CEC- you can use that wire as a switched ignition source https://cimg0.ibsrv.net/gimg/www.cor...3e48477d33.png |
(Post 1599279788)
(Post 1599280344)
You are welcome-
I'm running the Derale piece- seems they have gotten their act together as far as the temp sensor - as the earlier ones were problematic. Summit sells it- so if I have a problem- they are easy to deal with. It really depends how much mods you want to do to the wiring- just using the starter terminal is the easiest - cost effect and really doing more you are at the point of diminishing returns. Just run a 1/0 GU wire from the battery to the starter and you'll be good to go. The terminals- search "Marine Rated Battery Fuse" the marine stuff seem to have much better quality than the car stuff out there actually Amazon has got some good deals https://www.amazon.com/stores/page/A...eb_13611584011 West Marine- https://www.westmarine.com/buy/blue-...09_273_007_517 The 'battery terminal type fuses'- a 75A for the fans and a 50A for the fusebox should be fine. As far as the fusebox outs- 20A for headlight motors- for the headlights you can use a circuit breaker (auto reset type) that fits in a fuse slot- 20A For the MSD - I'm thinking 10A- but check the owners manual. The relays- You can have the battery power hot at all times go to a relay- and have the relay turned on by a ignition wire. see below I really like using the "LED" blade fuse- light up when they are blown- WELL worth the few extra bucks!!!! https://cimg7.ibsrv.net/gimg/www.cor...2ce6efd62a.png As far as switched sources- here's how it works at the ignition switch- https://cimg9.ibsrv.net/gimg/www.cor...8808d9db7e.png Here's what's going on at the harness on the firewall- since you are not using the CEC- you can use that wire as a switched ignition source https://cimg0.ibsrv.net/gimg/www.cor...3e48477d33.png You sir, are amazing. Thank you so much for the detailed response, you have really taken all the guesswork out of it. |
Thanks!!!
I also want to thank you Richard454 for freely sharing this info,,, all awesome ideas,,,, I got through my EFI-Fuel pump wireing ok, but it's nice to have a friend to call on for extra info,,,, All this info just went into my files for future reference, ,, , thanks again,,,,,,,,,,,,,,,,,teddy,,,:thumbs:
here is how I'm setting up my auxiliary equipment fuse panel and my MSD box. THe hardest part is trying to get under the dash to run the wiring properly. Im only 5'10" barefoot and hovering below 190lbs so I'm pretty average and my elbows and hands all sliced up from rubbng on the dash and pedals. I took all these pics earlier tonight and then had a zip tie party cleaning everything up.....
The relays are wired the way Richard drew it up. I ran a line from the battery up along the drivers door sill, ( all my power goes on the driver side and all the readio signal going to the amp goes down the passenger side so there now static getting amplified. ) The power goes into the relay at blade 30 and it comes out the other side at 87 to the power lug on the new block. The block isnt grounded. The relay trip signal comes off the ACC blade and goes in the 86 blade. the ground side comes out the 85 to the birdcage https://cimg1.ibsrv.net/gimg/www.cor...98cde96e02.jpg behind my dash running the LT blue power antenna line over to the stereo and the thin red line is MSD keyed on line going to the new fuse box https://cimg2.ibsrv.net/gimg/www.cor...d9df200e96.jpg old fuse box with new style Blown Fuse Indicator blade fuses. I cant find those adapters anymore. Somone must have done something stupid with them and you cant get them anymore I guess. THe red wire going to the ACC blade in the center of the pic is the trigger for the realy to the new box https://cimg3.ibsrv.net/gimg/www.cor...9b6aaea84b.jpg new fuse box mounted nexxt to the old box. I had to mount it side ways since there is no room under there because of the clutch. zthe back is sealed so Its not a hazard, theres just no room under there to put it any where and still be able to replace fuses https://cimg5.ibsrv.net/gimg/www.cor...fbe169d2f8.jpg a view of the blown fuse indicators on the new block. All my new wiring has painters tape labels so I can draw a new wiring schematic on the back of my laminated one https://cimg6.ibsrv.net/gimg/www.cor...db08615580.jpg power supply to the box is the big lug with te nut on it, I will either put a rubber boot over the bolt or cover it in RTV https://cimg8.ibsrv.net/gimg/www.cor...9869b3a477.jpg https://cimg9.ibsrv.net/gimg/www.cor...c6af806046.jpg kill switch mounted between the seats. Its not pretty but I can kill the car power if I have an electrical fire pretty quickly. I can just unscrew the handle and take it with me too if I get paranoid at a show https://cimg2.ibsrv.net/gimg/www.cor...360ff324e7.jpg fuses for the amp and sub woofer https://cimg3.ibsrv.net/gimg/www.cor...7e12e70c83.jpg pretty huge blade fuses. The fuses and wiring all came with a subwoofer kit. https://cimg8.ibsrv.net/gimg/www.cor...31d145603d.jpg quick connect for trickle charger https://cimg0.ibsrv.net/gimg/www.cor...6d23630503.jpg trickle charger wire/ fuse and sub/ amp wires/ fuses https://cimg1.ibsrv.net/gimg/www.cor...3bbb51e28e.jpg stereo setup, not much availble space with the top stored. I like how some peop;le hid theres in the storage compartments but I didnt want to get them too hot and I have my jack and tools in there anyway https://cimg3.ibsrv.net/gimg/www.cor...0787147d31.jpg roof down but still good sound. You can see the limitations. https://cimg8.ibsrv.net/gimg/www.cor...36376f4ba8.jpg this is the FM multiplexer behind the passenger side dash pad https://cimg0.ibsrv.net/gimg/www.cor...d528b0e27f.jpg you can see its location. I removed it and mounted the MSD box there. These are older pics for reference. https://cimg1.ibsrv.net/gimg/www.cor...4e6626a4d0.jpg this is the MSD wiring going through the firewall. I will RTV the openning closed https://cimg2.ibsrv.net/gimg/www.cor...351549d039.jpg I had to mount it upside down so that the wires wouldnt interfere with the center bezel, it sits pretty far into the dash at that height. More wiring to zip tie and organize.....I put the box in here because I couldn't find anywhere in the engine compartment that would be functional and look good. At least it will stay cooler on this side of the fire wall as well https://cimg3.ibsrv.net/gimg/www.cor...2b7af99832.jpg this is the fan relay mounted on the radiator support, the headlight relay is on the otherside. You can see the screws https://cimg5.ibsrv.net/gimg/www.cor...7e4289b977.jpg headlight relays looking down along the hood https://cimg6.ibsrv.net/gimg/www.cor...1f98e04f65.jpg wiring hidden in with the vacuum hoses and original wiring. Those are the self resetting breakers. 30 amp each if I remembe. The green switch is on the ground wire going to the T stat for the fan. I can flip it to kill the fan if I need to have the key in the on position while working on something. https://cimg9.ibsrv.net/gimg/www.cor...42c0ef4579.jpg wiring hidden in the original wiring run. THe MSD coil wires are sitting on the coil. it ususally had the shielding installed but I had to remove it to tighten the new oil pressure line |
(Post 1599286208)
https://cimg1.ibsrv.net/gimg/www.cor...98cde96e02.jpg behind my dash running the LT blue power antenna line over to the stereo and the thin red line is MSD keyed on line going to the new fuse box https://cimg2.ibsrv.net/gimg/www.cor...d9df200e96.jpg old fuse box with new style Blown Fuse Indicator blade fuses. I cant find those adapters anymore. Somone must have done something stupid with them and you cant get them anymore I guess. THe red wire going to the ACC blade is the trigger for the realy to the new box https://cimg3.ibsrv.net/gimg/www.cor...9b6aaea84b.jpg new fuse box mounted nexxt to the old box. I had to mount it side ways since there is no room under there because of the clutch. zthe back is sealed so Its not a hazard, theres just no room under there to put it any where and still be able to replace fuses https://cimg5.ibsrv.net/gimg/www.cor...fbe169d2f8.jpg a view of the blown fuse indicators on the new block. All my new wiring has painters tape labels so I can draw a new wiring schematic on the back of my laminated one https://cimg6.ibsrv.net/gimg/www.cor...db08615580.jpg power supply to the box. I will either put a rubber boot over the bolt or cover it in RTV https://cimg8.ibsrv.net/gimg/www.cor...9869b3a477.jpg https://cimg9.ibsrv.net/gimg/www.cor...c6af806046.jpg kill switch mounted between the seats. Its not pretty but I can kill the car power if I have an electrical fire pretty quickly. I can just unscrew the handle and take it with me too if I get paranoid at a show https://cimg2.ibsrv.net/gimg/www.cor...360ff324e7.jpg fuses for the amp and sub woofer https://cimg3.ibsrv.net/gimg/www.cor...7e12e70c83.jpg pretty huge blade fuses. The fuses and wiring all came with a subwoofer kit. https://cimg8.ibsrv.net/gimg/www.cor...31d145603d.jpg quick connect for trickle charger https://cimg0.ibsrv.net/gimg/www.cor...6d23630503.jpg trickle charger wire/ fuse and sub/ amp wires/ fuses https://cimg1.ibsrv.net/gimg/www.cor...3bbb51e28e.jpg stereo setup, not much availble space with the top stored. I like how some peop;le hid theres in the storage compartments but I didnt want to get them too hot and I have my jack and tools in there anyway https://cimg3.ibsrv.net/gimg/www.cor...0787147d31.jpg roof down but still good sound. You can see the limitations. https://cimg8.ibsrv.net/gimg/www.cor...36376f4ba8.jpg this is the FM multiplexer behind the passenger side dash pad https://cimg0.ibsrv.net/gimg/www.cor...d528b0e27f.jpg you can see its location. I removed it and mounted the MSD box there. These are older pics for reference. https://cimg1.ibsrv.net/gimg/www.cor...4e6626a4d0.jpg this is the MSD wiring going through the firewall. I will RTV the openning closed https://cimg2.ibsrv.net/gimg/www.cor...351549d039.jpg I the to mount it upside down so that the wires wouldnt interfer with the center bezel. it sits pretty far into the dash at that height. More wiring to zip tie and organize https://cimg3.ibsrv.net/gimg/www.cor...2b7af99832.jpg this is the fan relay mounted on the radiator support, the headlight relay is on the otherside. You can see the screws https://cimg5.ibsrv.net/gimg/www.cor...7e4289b977.jpg headlight relays looking down along the hood https://cimg6.ibsrv.net/gimg/www.cor...1f98e04f65.jpg wiring hidden in with the vacuum hoses and original wiring. Those are the self resetting breakers. 30 amp each if I remembe. The green switch is on the ground wire going to the T stat for the fan. I can flip it to kill the fan if I need to have the key in the on position while working on something. https://cimg9.ibsrv.net/gimg/www.cor...42c0ef4579.jpg wiring hidden in the original wiring run. THe MSD coil wires are sitting on the coil Seriously, thank you. This is an AWESOME thread! |
That would be awesome to be able to do. You can add extra fuse blocks and junctions exactly where you need them. Just keep in mind the other parts that need to fit into tight areas and if you are running headers or not so you dont get to close to the pipes in the engine compartment if you use the lower fore wall in the engone compartment. And also remember how many wire runs and and how little room there is behind your dash gauges. And did you take pics of where your big wire loom went behind the tach and speedo. Different years ran it different ways and its a good ole fun time getting the dash back together. PM or post up if you want any other pics. Its not a problem, I'm sure others will post the fun they had behind the dash....
You are welcome guys-
(Post 1599286379)
old fuse box with new style Blown Fuse Indicator blade fuses. I cant find those adapters anymore. Somone must have done something stupid with them and you cant get them anymore I guess. THe red wire going to the ACC blade in the center of the pic is the trigger for the realy to the new box.
Here's another neat product- Modular fuse & relay- I'm up tp about 20+ in my car!!! I used three of them to replace my fusebox...and moved it to the kickpanel to make fuse replacement possible with out being a gymnast!!! https://cimg1.ibsrv.net/gimg/www.cor...184295eb73.jpg https://cimg6.ibsrv.net/gimg/www.cor...b000b39bd8.jpg Here's a neat tool that will keep you from going insane- shrink tube labeler- https://cimg3.ibsrv.net/gimg/www.cor...111707ab04.jpg https://cimg4.ibsrv.net/gimg/www.cor...82ac1ec709.jpg https://cimg5.ibsrv.net/gimg/www.cor...3c657314c6.jpg |
awesome
I need those labels. The fuse box is a great idea too |
I think it's pretty neat, how we all approached this problem from different angles. I had room on the '74 firewall, because there wasn't a vacuum can for the wipers there anymore. My MSD box is actually mounted vertically on the passenger kick panel!
