Turn Signal Won't Cancel
On my '76 the turn signal would just stay on either direction after the turn so I purchased a new complete switch. After the difficult process of replacing it I still find that my turn signal won't cancel in either direction. Any ideas why this might be??
Thanks |
If you do a full rotation of the steering wheel, does it still not cancel? Did you replace the cancel cam when you replaced the switch?
Doesn't matter how far I turn the wheel it won't cancel. The cancel cam. . .does it come as part of the turn signal switch? I can't say I remember replacing a cancel cam. What does it look like?
After a little further investigation I did, in fact, install the cancel cam. However, I'm not sure that it might be 180 degrees out of alignment. I'll have to pull it apart and check it.
Thanks for your help!! |
Originally Posted by BLDun
(Post 1599280388)
My cancelling cam was installed 180 degrees out, it can be done with a little extra effort. Then it takes a lot of wheel turning to get the signals to cancel.
Originally Posted by CA-Legal-Vette
(Post 1599292183)
You can’t install the cam 180 degrees out, but you can the steering at the rag joint. If you do, it will seem yo work correctly in 1 derection and not the other.
you can put the steering column on 180 degrees out by bolting the 2 bolts on the rag joint with bottom of wheel up when it should be down.
