7MT clutch full in
Do you press the clutch full in for every shift or just below the engagement point, is there any harm on the clutch if it's not depressed all the way to the bottom during shifting?
All the way bud. If you don't take the pressure off the plate, you add a little more stress to the system (throwout, etc), and that transfers to the trans. The second gear cold grind is a good example. If you FULLY push the clutch in, you'll notice far less of it.
You can certainly do it if you get past 'the point', but you're better off hitting the floor and knowing. :thumbs: |
The answer to your question is no, there is no harm to the clutch if not pushed all the way to the floor, as long as the clutch is fully disengaged when you shift. The problem when trying to shift that is it's very difficult to know exactly when fully disengaged unless you feel it hit the floor. I've experimented with this method for shifting and for me it just is not difficult to get it right overtime unless I get very near, or to, the floor. You can shift without harming the system though,, without pushing all the way to floor.
I've noticed that when I push mine all the way to the floor it jerks upon release. If I just push in until I feel the gear release it engages smoothly.
You should be able to feel when it starts to engage when releasing the petal. When you shift make sure your petal is below that point. Never in 60 yrs have I put the petal to the floor. Only time is when starting my C7
So it comes down to theory vs practice. Is there any harm as long as the clutch is in fact fully disengaged? No. Can you burn the clutch if you don't get it right? Yes.
My BMW M3 has an adjustable clutch stop. It physically prevents you from pushing the clutch further than required. And it's adjustable to compensate for clutch wear. So the clutch starts to bite IMMEDIATELY, (ok, .005" of movement) It works quite well. I've never seen the need on the C7.. Mine seems to start biting right off the floor. |
Great answers , thanks guys
Originally Posted by rrsperry
(Post 1599317016)
GET THE A 8 AUTOMATIC , PROBLEMS SOLVED !!! :D
Rich |
Full-in minimizes chance of excessive clutch wear and synchro wear. There is no extra wear to the clutch system due to pushing the pedal to the floor.
Originally Posted by Vette Ski
(Post 1599317242)
Rich |
(Post 1599317242)
Rich GO! :thumbs: |
Clutch pedal? We don't need no stinking clutch pedals!!!!!!
I knew a girl, whose husband was a truck driver. She could shift a stick without the using the pedal - it was amazing! |
(Post 1599317016)
My BMW M3 has an adjustable clutch stop. It physically prevents you from pushing the clutch further than required. And it's adjustable to compensate for clutch wear. So the clutch starts to bite IMMEDIATELY, (ok, .005" of movement) It works quite well. I've never seen the need on the C7.. Mine seems to start biting right off the floor. Did consider clutch stop for M3 but never did it for fear of warranty issues |
(Post 1599317242)
Rich |
(Post 1599317242)
Rich
Originally Posted by Corgidog1
(Post 1599318704)
Good advice—no problems at all with the A8....
Originally Posted by boss2k
(Post 1599317552)
Never !!
Originally Posted by LuisZ51
(Post 1599319248)
:rofl::leaving:
Rich |
All the way, everytime... on everything for over 60 years, including race cars. Never ever had a clutch issue on anything. :thumbs:
As for the A8 solving anyone's problems I suggest a search here...:lol: :lol: :lol: |
(Post 1599317242)
Rich That's a whole bunch of other problems. |
