Front Suspension rebuild recomendations
I need to rebuild the front end on my 77. It seems the various Vette parts suppliers put together pretty good kits (ball joints, tie rod ends, bushings and such). Is there any kit that's better than the rest or am I better off buying individual parts?
Thanks |
I like the Van Steel kits, good Moog parts.
1963-82 Rubber Front Suspension Rebuild Kit (FSK-03)
https://www.vansteel.com/index.cfm?f...p=3011&ID=2991 |
I like Van Steel (just got my new spring from them) but if you go to rock auto you'll be able to get all the same moog parts for about $300.
M |
I just redid my front suspension with Moog chassis parts when appropriate, and Energy Suspension poly bushings for the swaybar and control arms. (Actually an SPC adjustable upper control arm, but I also have the poly bushings for the stock arms). Rock Auto is the way to go, as you know exactly what you get, though you can also get everything from Summit or Jegs. I also spec'ed turnbuckle tie rods with jam nuts, vs. the clamp-style of the stock C3.
What are you doing for shocks and springs? |
Avoid the middle man if you want to save a few bucks. Your local auto parts store can get you the mood parts, but you have to talk to them to make sure they know what they are talking about
I installed Wilcox Deluxe kit 4+ years ago. Great price and quality.
If you have any interest in upgrading your suspension now is the time to do it. Honestly everyone should replace their upper controls with newer units that have geometry corrections in them to make the car handle better at interstate speeds.
+1 for Rock Auto. I got all moog parts for my front end as well as the energy suspension poly bushings for the entire front end, all for a lot less than the kits cost.
Originally Posted by PainfullySlow
(Post 1599332334)
A little bit off topic but I think relevant. I overhauled my front suspension last year and in the process decided to clean up the frame. Had all the radiator stripped out as I am in the process of rebuilding and customizing the car. Anyhow, the frame on my car has always been supper clean and rust free, but on very close inspection I noticed small cracks in the steel on the shock mount towers, if you can call them towers but I guess that you know what I mean. Cracks were only on the passenger side. I welded them up but as a precaution I fitted a strut brace to spread the load. I use an electric fan so clearance was no issue, I do not think you can use the mechanical fan with a strut brace but if nothing else I would strongly suggest that you get in there and check yours out for any cracking. Hope this is useful information.
Pete |
Speeddirect front spreader bar on my 78 L-82 4 speed with a mechanical stock fan fits perfectly.....
https://www.speeddirect.com/index.ph...3-spreader-bar |
+2 on the Willcox Deluxe Kit. They frequently run weekend sales - https://willcoxcorvette.com/willcox-special-sale
Originally Posted by jb78L-82
(Post 1599335334)
https://www.speeddirect.com/index.ph...3-spreader-bar https://cimg5.ibsrv.net/gimg/www.cor...226168347.jpeg |
Van Steel.
All Moog parts. |
All the parts in our SU01 branded kits are Moog and/or Federal Mogul (which owns Moog). I will not install any other kit in my shop.
https://willcoxcorvette.com/catalogs...year=28&q=su01 |
Originally Posted by Willcox Corvette
(Post 1599342334)
Originally Posted by Gunfighter13
(Post 1599342476)
Good deal on the deluxe kit for $299.00
Willcox |
Originally Posted by Kacyc3
(Post 1599331333)
Thanks |
Originally Posted by drspencer
(Post 1599345379)
Please tell me more.
Thanks If you are considering replacing your arms with aftermarket I am going to assume that keeping the car stock is not a concern for you. At the very least you may want to consider going to poly bushings, it will make the car handle a lot better. |
(Post 1599342334)
https://willcoxcorvette.com/catalogs...year=28&q=su01 OP, The important thing to consider is to get the best quality parts. In the suspension kits it is the quality of rubber and the quality of the associated components in the kits. Wilcox’s kit looks just like the Moog/Federal Mogul kit I received through Van Steel. I don’t think you could go wrong with either kit. |
