Break upgrade?
Hello,
I'm thinking of tracking my ZR-1 and have concerns about the factory breaks not holding up. What is the easy/best upgrade for the Z? Thanks in advance. |
I bought wilwoods but haven't installed them yet
https://www.wilwood.com/BrakeKits/Br...22+Front+Rotor https://www.wilwood.com/BrakeKits/Br...22+Front+Rotor |
Originally Posted by Scuderia09
(Post 1599327277)
Hello,
I'm thinking of tracking my ZR-1 and have concerns about the factory breaks not holding up. What is the easy/best upgrade for the Z? Thanks in advance. Post 122 - Wilwood C5 Z06 Brake Conversion with Sawblades https://cimg7.ibsrv.net/gimg/www.cor...6e84b08c75.jpg |
^Iagree....that is the best Bang for the Buck if you truly require an upgrade. I've done that upgrade on my '92 LT1 specifically for track use....but I had the BASE brakes, which the ZR-1 never had. ZR-1 came with the optional "J55" brakes with a ~13"' rotor.
Two things, however; C5 brakes, and C5Z06 brakes are the same...except the Z06 caliper was painted red. So save money and skip the "Z06" part. Second, I'd start by getting good track pads and good brake fluid. The stock brakes are very likely, better than good enough. :yesnod: |
