Restoring 1970 front grills
I'm restoring my 1970 front grills that I spray bombed black 15 years ago. I used paint stripper to get most of the old paint off. I hand sanded the middle grill for over three hours today to get it ready for paint.
Is there an easier way? Will sandblasting damage the (I assume pot-metal) grill? What media would be safe if I can use a blaster? I would hate to ruin a nice set of original grills. Thanks https://cimg1.ibsrv.net/gimg/www.cor...45981b01b3.jpg |
I think that sand blasting would be detrimental to the pot metal surfaces. Even small grit at low pressure can do damage if held very long in one spot. And, if pressure is too low, the paint won't come off. Soda blasting might be a better choice. But, my preference would be chemical stripping. Some strippers are gel products which can remain in contact with the part, even though is is an odd shaped part. And the front grills are certainly, 'odd shaped'.
I'm curious about what variety of responses you may get on this thread. :bigears |
Originally Posted by Crimson Thunder
(Post 1599328073)
Is there an easier way? Will sandblasting damage the (I assume pot-metal) grill? What media would be safe if I can use a blaster? I would hate to ruin a nice set of original grills. Thanks The grille portion is easy and looks great, the chrome not so much. https://cimg8.ibsrv.net/gimg/www.cor...ac5b5dfeff.jpg https://cimg9.ibsrv.net/gimg/www.cor...7ce8c0c70d.jpg I reckon with some more time and care you could get 'usable' results |
I did 3 sets in the past. 7T1vette remarks are right on. I used the gel paint stripper and lacquer thinner and have to say that that grill paint is some of the most difficult to remove and took a lot of time to get it prepared for paint. After paint removal you could "smooth" out, by sanding, the pitted surfaces that will be painted.
I have a soda blaster, but did not use it because of a couple reasons; I think it would be to gentle on that difficult paint and it makes a big mess! On a side note, the soda blaster makes cast aluminum parts, like valve covers and manifolds look like they were just cast. I think that brit vette, Stuart's results look great, but masking off the chrome is a must. Here are a finished set of driver quality grill I did. https://cimg9.ibsrv.net/gimg/www.cor...a3a9f0f492.jpg |
Toylman, what brand of gel stripper did you use? Your grills turned out great.
My issue with chemical strippers is that it can be annoying to get into the corners. I would blast with walnut shell media and call it done.
(Post 1599329705)
I'm not sure that walnut shells would get into those corners, either. But, that would be a much better medium than sand for those grills.
Originally Posted by toylman
(Post 1599330382)
I have a can of Jasco Premium Gel. I think I got it from Lowes. It says "removes multiple layers"; sure didn't do that. I remember applying multiple layers of gel and using a small brass brush, but at least the existing chrome was not harmed.
(Post 1599332155)
That's good to hear as I just bought 2 aerosol cans of that stuff from Home Depot. I guess you can't get the good aircraft stripper anymore. Damn EPA.
Originally Posted by Z06LMB
(Post 1599334049)
I just picked up a spray can of Aircraft stripper by Kleen Strip at Walm, nothing works better.
(Post 1599334697)
I've checked two Home Depots, Lowes, O'Rilleys, and a WalMart. I can't find it anywhere anymore. Tomorrow I'm going to try an old Ace Hardware.
Would it help if I took pictures of the cans with the upc label? I know this stuff is on the shelves, I did notice considerable stock at Grangers this afternoon. |
Vapor blasting would do a great job on those with no damage
I use the fine media and blast the grills keeping my gun a a pretty good distance. I also tape off all the chrome as well as the lamp socket. Once completed I go over the unit with wet sand paper and shoot 2 coats of cast blast. Just another way..................................... .................
RVZIO https://cimg1.ibsrv.net/gimg/www.cor...67ed8881dd.jpg Sorry, only picture I have. |
I am pretty sure the ORIGINAL paint is the same as the 1970-1974 Z28 Wheels.. - which is simulated magnesium - Zero gloss Suede textured
https://cimg1.ibsrv.net/gimg/www.cor...21447f8896.jpg |
I use Rustoleum Aircraft paint stripper. Got it at AutoZone in a gallon can. Works great! be careful using it, wash off immediately if you get it on your skin!
Russ |
I got one finished today. It's not perfect but 100% better than it was before.
https://cimg0.ibsrv.net/gimg/www.cor...dd9ee6a493.jpg |
There ya' go! :thumbs:
