What is best source for quality A-frame bushings?
I am about to replace the A-frame and trailing arm bushings on my 69. Does anyone know of best source to get quality bushings? Thx
Wilcox
Originally Posted by daletraylor
(Post 1599330861)
Originally Posted by PainfullySlow
(Post 1599332372)
Define 'quality'? OEM rubber style? As was said above, Wilcox or a Corvette specialty shop. Poly? I get Energy Suspension from Rock Auto.
Found them mentioned in an older Corvette Forum post. |
Order direct from MOOG.
Carter |
What /Who is MOOG?
(Post 1599345965)
What /Who is MOOG?
Thanks for the info. I will check it out!
The search for "bushings" on the Fed Mogul website came up empty, so no help there!
MOOG K304 are the lower control arm bushings.
Not sure about trailing arms, but I think it's MOOG K200921 https://www.summitracing.com/parts/m...model/corvette https://www.summitracing.com/parts/mog-k200921 |
Zwede, Thx again. I did not think about going to summit racing website,I went directly to Federal Mogul website.
I like these guys, lots of cool info on their website also
https://www.duntovmotors.com/corvette-parts1.php |
Originally Posted by OUFAN76
(Post 1599352234)
When you get ready to install them ,put them in your freezer for a couple of day, makes the job a snap
(Post 1599346999)
https://www.fme-cat.com/Application....ga=Y&back=true |
Dale, my advice is to stay with the rubber bushings. The poly bushings really have a tendency to squeak. I have installed both types, several times and will only use rubber (as original) from now on.
Greg |
