Temper Camaro '69 with C5 chassis swap
Going to touch base on the big aspects of this build to get everyone caught up. This is my second go around with this car as I change my plans half way through and started basically from scratch. I started with a 1969 Camaro and wanted a lot from it. Serviceability, parts availability, performance, and comfort.
Currant build parts: Anvil Carbon fiber front end, deck lid, rear spoiler, and mirrors LSA with LS3 dry sump crank 2 C5 chassis Infinity Box CAN Buss chassis control system C6 dash swap Full carbon fiber rear bumper NACA ducts for rear coolers SpeedHut CAN Buss gauges Flush mount front and rear glass Things to come: TR6060 transaxle with trans and diff cooler C6 rear cradle Carbon front inner fenders Lets start with what the goal is when I'm done. Kris Horton did my exterior renderings. Ben at Street Rod Designs did the interior. As you can see from the minor body mods, I have a lot of metal and carbon work ahead of me. https://cimg8.ibsrv.net/gimg/www.cor...b9004ed082.jpg https://cimg0.ibsrv.net/gimg/www.cor...ed7f81fc54.jpg https://cimg2.ibsrv.net/gimg/www.cor...cad4f55e97.jpg On the weekends I knock out the big projects on the car at work since I live in an apartment and have no where else to work on it. Lets start with those. After lots of measuring I found that it was possible to put the C5 chassis into my car if I made my own frame and make it 3.5" longer. I bought 2 frames, one had front damage and the other was perfect. I had to make new rails and I was able to stuff them into the outer rocker panels. https://cimg7.ibsrv.net/gimg/www.cor...49398687e1.jpg https://cimg8.ibsrv.net/gimg/www.cor...a8a22f722f.jpg https://cimg1.ibsrv.net/gimg/www.cor...0f26300ec9.jpg https://cimg5.ibsrv.net/gimg/www.cor...d3ff374daf.jpg https://cimg6.ibsrv.net/gimg/www.cor...f62d2b3b41.jpg https://cimg8.ibsrv.net/gimg/www.cor...1177d74d3f.jpg |
I made a new panel for the passenger rear to match the driver side and boxed off the fuel tanks where the B pillar would have been.
https://cimg9.ibsrv.net/gimg/www.cor...f8ea27a7da.jpg With the frame set I sent the car and the frame to the blaster and had them epoxy coated. Once back I slid the frame in like a matchbox. https://cimg6.ibsrv.net/gimg/www.cor...f3eddc9d15.jpg https://cimg7.ibsrv.net/gimg/www.cor...a7487a99f5.jpg After mounting the front end and lots of measuring I was ready to weld the two together. https://cimg3.ibsrv.net/gimg/www.cor...8ff2851fa8.jpg https://cimg4.ibsrv.net/gimg/www.cor...6079cf2819.jpg https://cimg6.ibsrv.net/gimg/www.cor...62dd6568ac.jpg Now with the hard part done I was able to move onto tin work. I made tubs and the rear floors out of 18g steel. https://cimg6.ibsrv.net/gimg/www.cor...9edfc6f3da.jpg https://cimg7.ibsrv.net/gimg/www.cor...9fbb0ef3f0.jpg https://cimg8.ibsrv.net/gimg/www.cor...44fee8f0f7.jpg https://cimg0.ibsrv.net/gimg/www.cor...ad2db88ad2.jpg I think that brings us up to speed on the big parts of the project. |
Lets knock out the small projects I mainly tackle during the week after work at the shop.
Lets start with the door handles. I'm running C6 latches so I have touch button handles. I needed a recess for them so I pounded out some metal and planshed it. https://cimg1.ibsrv.net/gimg/www.cor...1d1825c5e1.jpg https://cimg2.ibsrv.net/gimg/www.cor...43842a3943.jpg I wanted to tuck the rear bumper, but I didn't like the body lines with the small bumper so I made my own. https://cimg2.ibsrv.net/gimg/www.cor...8e6d3df927.jpg https://cimg3.ibsrv.net/gimg/www.cor...0e02c6fd40.jpg Now that I had the shape I wanted I finished it and painted it so I could make a mold from it. https://cimg5.ibsrv.net/gimg/www.cor...178c7cb6ac.jpg https://cimg8.ibsrv.net/gimg/www.cor...c7f1047ade.jpg https://cimg0.ibsrv.net/gimg/www.cor...2ec3a64d62.jpg After all of that I could pull my carbon fiber bumper from it. https://cimg3.ibsrv.net/gimg/www.cor...7bff241cb8.jpg Because its generic looking and easy to make look like it belongs in any car I went with a C6 dash because it fit and was cheap. However nothing worked since I'm not running a factory control system. I started with the bezel and the non functional buttons. I needed to put 2 more gauges somewhere and though that'd be a great place for them. Then wrapped it in carbon. It will get a Matte paint finish. https://cimg1.ibsrv.net/gimg/www.cor...c2ab2f309c.jpg https://cimg5.ibsrv.net/gimg/www.cor...24915aef90.jpg https://cimg0.ibsrv.net/gimg/www.cor...ed95075e48.jpg https://cimg1.ibsrv.net/gimg/www.cor...eb9d023002.jpg https://cimg4.ibsrv.net/gimg/www.cor...0411f5ff18.jpg |
With the bezel out of the way I needed some gauges. I used a C6 cluster and cut everything out. I laid out the gauges then cut angle rings to angle them like a C6. I used a T shirt and epoxy to get the shape then wrapped that in carbon. It will also get a Matte paint finish.
https://cimg3.ibsrv.net/gimg/www.cor...72149b66fa.jpg https://cimg4.ibsrv.net/gimg/www.cor...7a45691694.jpg https://cimg8.ibsrv.net/gimg/www.cor...5808b77e80.jpg https://cimg1.ibsrv.net/gimg/www.cor...813e2ea4f1.jpg With two of the major parts done and ready for paint it was time for the center console. I decided on a double din radio, Dakota Digital HVAC controls and my power window switched on it. I had to fiberglass the hole from the factory then I bonded the din frame in. I also bonded in the access cover. It also got covered in carbon and will be a matte finish. https://cimg8.ibsrv.net/gimg/www.cor...f90aeef9a7.jpg https://cimg0.ibsrv.net/gimg/www.cor...df3573dcc4.jpg https://cimg1.ibsrv.net/gimg/www.cor...20572c3763.jpg https://cimg3.ibsrv.net/gimg/www.cor...d2921fd4eb.jpg Needing to mount the C5 pedals for the booster and slave I made a metal copy of the factory fiberglass composite firewall. https://cimg0.ibsrv.net/gimg/www.cor...228197ff99.jpg On my Anvil carbon mirrors I added a little safety with some LED turn signals. https://cimg5.ibsrv.net/gimg/www.cor...4f6630ef25.jpg https://cimg6.ibsrv.net/gimg/www.cor...0b90501be1.jpg I think that about does it for the most part. I'll keep this thread up to date as I progress with the car. |
Wow!
Now this is a great project!!!
You've got some mad skillz. Post lots of pics. I love the stance! :cool: |
Originally Posted by LTC Z06
(Post 1599343644)
Wow!
Originally Posted by ILLUSHN
(Post 1599345013)
You've got some mad skillz. Post lots of pics. I love the stance! :cool: Right now the bottom of the rocker is right about 5.75” in the back and a little lower in the front. Which is a lot where a vette frame is if you measure to it and not the body penals. It’s as low as I can go as anything lower and the tires will hit the hood hinges. |
cool
Awesome work! I hope you plan on pics thru the whole process.
PS-Very impressed with your wheel tubs and floor. Looks as nice as a chassis shop would do Jimmy |
Originally Posted by JimmyS5600
(Post 1599349159)
PS-Very impressed with your wheel tubs and floor. Looks as nice as a chassis shop would do Jimmy Thank you, I'm just as impressed with how the tubs came out too, it was my first time using an english wheel to shape anything. |
This is awesome! I'm currently putting a corvette drivetrain into a '74 Toyota Hilux (I have a thread on here as well), but mine has a lot less carbon fiber and nice looking things. Although, after seeing your carbon work I now want to get off my ass and make some small stuff to learn. Beautiful work, you clearly have an incredible eye for shaping things.
Originally Posted by hambler
(Post 1599351150)
I saw it. Pretty cool swap. The carbon is the easy part I'm finding. The hard part is making the buck perfect and then making a mold then making that perfect. If you get those two things right the carbon is just the reward for the hard work. Now if you just want to do a carbon overlay, thats pretty easy to. Whats hard about that is carbon fabric doesn't stretch or form like fabric and is hard to lay if you have lots of angles to work with. If its just a flat surface all you do is prep the base with black paint, coat in epoxy, lay some fabric then wet out the carbon, add a second and maybe 3rd coat of epoxy, wet sand then clear coat. Its time consuming, but not hard. |
now more pics of the susp and drive line
Originally Posted by dmaxx3500
(Post 1599375456)
Holy Moses that's some amazing work!:cool:
"I used a T shirt and epoxy to get the shape then wrapped that in carbon" - that is boss-level stuff going on! I might have to print that on a t-shirt:lol: |
:cool:
Gonna look great when you get finished :thumbs: |
Looks great so far! Am I seeing correctly that you made a mold for the bumper to make it out of carbon, but just did carbon overlays on the interior pieces? Just curious, because if you have a mold of that C6 instrument cluster surround you could sell some or sell the mold pretty easily.
Originally Posted by acroy
(Post 1599378035)
Originally Posted by 001pewter
(Post 1599381859)
:cool:
Originally Posted by PCMusicGuy
(Post 1599387662)
Update: I didn't feel like I got a lot done Saturday since it took longer than I hoped it would, but I got the tin work finished up on the trunk metal and its ready to get epoxied. After that it will be ready to weld in for good. On the bottom side I got the support welded up and it really stiffened up the metal and took the rattle sound away when knocking on it. Now its more of just a thud. Oh, I also threw a 335/25-20 under the back of the car. It will physically not fit because of the upper control arm. If I cut the quarters and moved it out then it would. I have to assemble the front end and see if a 315 on a 19x10 will clear. If I have to cut the front fenders to fit even a 295 then I'll have to also cut the rear to match. https://cimg7.ibsrv.net/gimg/www.cor...87bdbf5b1d.jpg https://cimg8.ibsrv.net/gimg/www.cor...20b04e20f3.jpg |
Wowsers...... thats insane !!!!
Cool work....... Subscribed..... |
Originally Posted by Warpdrv
(Post 1599428856)
Cool work....... Subscribed..... Lots done Saturday. Seat montes are done, factory corvette floor cut and fit ready for finishing. The cut sections will be bonded back together and then they’ll all be sealed with 12k carbon. AC mounted and fit the old firewall bracket fit the new chassis better than I thought it would. Lots of clearance everywhere for ducting and electronics. I got started on the new firewall with a bunch of thinking and drilling out spot welds. I have a good plan in mind for it to tie everything together and keep the wipers out of the car and not totally have engineer something to make them work. https://cimg5.ibsrv.net/gimg/www.cor...4ca618b9a.jpeg https://cimg4.ibsrv.net/gimg/www.cor...502799974.jpeg https://cimg6.ibsrv.net/gimg/www.cor...07176ea9b.jpeg https://cimg4.ibsrv.net/gimg/www.cor...cc48d5d50.jpeg https://cimg3.ibsrv.net/gimg/www.cor...f84d38a12.jpeg https://cimg5.ibsrv.net/gimg/www.cor...6f6db5a01.jpeg |
