Oil film on pan
Question how easy is it to blow the front oil seal on a turbo car? Every time I change oil I notice a film where the drain hole is. It’s coming from above the drain hole somewhere. My assumption is it’s a seal. If so how much to replace and what is the best type for a turbo car
Do you have any issues with your oil pressure readings? I had a steady leak and it ended up being the oil pressure sensor. Here is some info, I changed mine by pulling the windshield trim piece and cutting the through the shroud to access it, it's right behind the manifold. It only takes about 30-40 min max doing that way. https://www.corvetteforum.com/forums...placement.html
No problems with pressure. Holds steady
If you have a film around the drain hole its probably not the front seal. My guess would be the drain plug is leaking or the oil pan gasket itself is leaking. Try to trace the oil back to the point of origin.
