ARP Head Studs
Any benefit for SC boost applications?
Also, if I put a kit like these on am I able to install the heads with clearance if the shortblock is still in the car? |
Originally Posted by Tusc
(Post 1599350127)
Also, if I put a kit like these on am I able to install the heads with clearance if the shortblock is still in the car? You can install heads with studs if block is in the car. |
Also, there is a helllllll of a lot less clean up if you have to pull the heads off.
