E85 Flex fuel requirements for my setup
I want to install a flex fuel kit but am curious if I will also need a larger fuel pump and injectors.
My car and mods: 2012 Grand Sport manual A&A SC V3 Ti trim currently running about 9psi A&A stage 1.5 blower cam 80lb Bosch injectors boost a pump long tubes high flow cats and x pipe Exhaust *also what can I expect for HP gains on a full tank of E85? Thanks |
Yes you will need a larger pump, either new in tank pumps or external, and larger injectors.
i would expect about 50 rwhp gain from e85. |
Thank You for the info.
At least 1000cc if not bigger.
At least 800lph of fuel pump. Assuming you are going to turn it up. |
Originally Posted by Unreal
(Post 1599360347)
Please delete mods phone app placed this in wrong section.
LOLOLOL . 80lb injectors!???? Dont do it without upgrading. i have 1300cc and a triple pump, previous owner hooked it up.
